confused on spark plugs
hey fellas, i'm looking into changing out my spark plus this weekend with some ngk iridium IX plugs, now ive used the search trying to find the part number for those plugs for a 2001 cl type S, and its amazing how many people give totally different part numbers for ngk's for the same car, so can anyone please help me out and give me the one and only true part numbe for ngk iridium IX for a 2001 CL-S....
Blown is Best
This is off of http://www.ngksparkplugs.com/apps
2001 ACURA CL S 3.2 V6 J32A2 FI SOHC
Spark Plug - Part No. (Stock No.)
V-Power - ZFR5F-11 (2262)
G-Power Platinum - ZFR5FGP (7098)
Laser Platinum - PZFR5F-11 (4363)
Iridium IX - ZFR5FIX-11 (2477)
so according to ngk the type S and the premium use the same plug cause ngk shows the same part number when you select either engine for the 2001 cl
on the denso site they used to recomend IK16's for the Cl type S but 20's for the TL...i wouldnt go by the web site .id go with what you know to be the proper heat range
Boomer SOONER
Blown is Best
Originally Posted by ou sig
yes, every 2nd gen TL and CL use the same plug - you only need to change to a different plug if you add FI to your engine.
Premium
NGK: PZFR5F-11
Denso: PKJ16CR-L11
Type S
NGK: PZFR6E-11
Denso: PKJ20CR-M11
acuratl26
04-23-2020 07:30 PM
ITSJESTER
17
12-06-2018 02:29 AM
Joe Avesyan
09-29-2015 03:57 PM
