Comptech Supercharger
Old Apr 10, 2002 | 10:57 PM
darrinb's Avatar
///M POWER
Assuming that you have all the performance parts available for the CL-S and you get the supercharger when it becomes available do you think it is possible to run in the 12's??
BTW, who plans on dropping almost 5k for the supercharger?
Old Apr 10, 2002 | 11:05 PM
fbazakos's Avatar
on bin laden
Re: Comptech Supercharger
considering nobody runs 13's fairly (read: no nitrious), 50hp from the supercharge isn't going to bring it into the 12's ...
Old Apr 10, 2002 | 11:20 PM
BlackShadow's Avatar
O.G.
HELL NO!
Old Apr 10, 2002 | 11:31 PM
Nicky Pass's Avatar
Fuct in the hed!
I think its a waste to spend all of that money for 50hp.....It doesn't seem worth it.
Old Apr 11, 2002 | 12:04 AM
Infamuz's Avatar
Retired Post Whore
If its 150 HP+ then it is worth it.
Old Apr 11, 2002 | 12:15 AM
kHmER Co's Avatar
mister D
My goal is to get into the low to mid 13's.. N/a i think its possible
Old Apr 11, 2002 | 12:17 AM
fbazakos's Avatar
on bin laden
well that is easy ...
Old Apr 11, 2002 | 12:20 AM
kHmER Co's Avatar
mister D
yes it is.. if you have the $$$$$$
and plus the waiting game on res + mm2
Old Apr 11, 2002 | 08:15 AM
typeR's Avatar
he said N/A...that aint easy...3.5 upgrade, RES ,MMII, and slicks up front light weight wheels and oh did i say 7 grand later mid to upper 13's....
Old Apr 11, 2002 | 09:29 AM
spiroh's Avatar
mid-low 13s are harder then u think. You would have to do all the mods, and add RES + MM2, then maybe.
Old Apr 11, 2002 | 09:39 AM
gavriil's Avatar
Moderator Alumnus
For this car to get in the 12s, it will need some serious slicks. Dont forget that power alone will not get you through the 1320 feet faster.
And because I am sure that torque numbers will be equally affected by the use of a SC, I can tell you that the biggest problem will be traction. Even with 245s even if they are S03s.
Possibly that is why the 50HP gain, if that is even the case when it comes out. I would predict 100HP gain, just like with the S2000 SC. But how are we going to put it down on the ground when the torque will go from 232 pounds to 300 pounds?
Old Apr 11, 2002 | 09:40 AM
4thGSi's Avatar
STi
Well changing the supercharged pulley will raise the PSi, so hp could be increase more....
Jul 16, 2017 07:33 AM
CL-S progression 01
Jan 26, 2016 04:15 PM
Joe Avesyan
Sep 29, 2015 03:57 PM
k6biv
Sep 22, 2015 02:06 PM
