Comptech springs or Eihbach Pro-Kit?
Best D-Line in the NFL
Location: Gainesville, Fl for college, Palm Beach Gardens, Fl at Home
Well while we are at it, can we throw the differences between the H&R Sport Springs and Eibach Pro-Kit around? Arent they nearly the same drop and some guys need camber some dont?
Originally posted by Chopper
Get the CT, looks great, and no need for camber kit.
Originally posted by amisconception
will i need a camber kit for the eibach springs?
![Yes](https://acurazine.com/forums/images/smilies/yes.gif)
The eibach and the comptechs are a totally different drop. The eibach is much more drastic than the CT.
I have the H&R Sport and I'm not going to say they are the best, because i'll admit I am biased.
If you want to see pics of my H&R drop on stock rims and tires i'll post them.
Spectacular Aroma About
Comptech drop is very noticeable. It just looks stock after you get used to it. Depends what you are after. A friend of mine and I were riding around and I saw a CL and pointed it out. He said "why is it all jacked up in the air"? I told him beacause mine is lowered. (Comptech) Looks pretty much stock though. Except for the rake. You gotta love the rake to get the Comptechs.
Road Rage
Get eibach, the drop is PERFECT. and the ride isn't too bad. I haven't gotten my alignment so i don't know if i will need a camber kit or not. However, from my eyes my camber is not off
CL Newbie No More
The likelihood that camber kits will be required is greater with Eibach than with Comptech.
TQ > MPG
Originally posted by mrsteve
The drop of the Eibach is more than the H&R sports. With the H&Rs it is hit or miss if you need a camber kit, with the Eibach i'm almost positive you'll need it.
![Mad](https://acurazine.com/forums/images/smilies/mad.gif)
And Mrsteve, post those pics biiiitch.
I have the H&R sports, derelict has the eibach. We have had our cars parked next to each other and his still sits slightly lower than mine. It isn't a huge difference. He needed a camber kit, so do I. Last time I saw him he was planning on intentionally aligning his with negative camber to decrease rubbing. I have no rubbing with my H&R drop. Although I am very close.
pro-kit is 2.0/1.7.... but when settled the back is actually slightly lower than the front. I'm very happy with mine.
edit: I went ahead and had the intentional neg camber put in last alignment. It helped on about 2 of the 6 places on my normal commute that I always rub. I never rubbed on stock rims though.
I'm getting my rims early next month
You car's drop/rims and tires definitely looks awesome. Those Conti's are so thick though its crazy!
I didnt know that 235/45/17 rubber on stock rims stick out....I was planning on doing that when my 215/50/17 contis wear out.
Whats the best tire size for grip/acceleration and if it will throw off speedometer and odometer, by how much?
He doesn't have stock rims, he has 17" x 8" rims. 225/50/17 Totally different story. Conti's are also bigger than other tires, like the stock Michelin's, they just run slightly bigger even though the size is the same.
If you have a standard drop such as the H&R sport that isnt adjustable you can still eventually switch out your stock 17's with 18s right with no problem?
AWD Torque Monster
Koni's are so expensive though, how often will you really adjust your shocks... maybe twice till you get it right...
Well when you load the trunk up, it still shouldnt cause any problems, itll just make the back sit lower for a little bit, this drop isnt that big its only 1.75/1.5
Full-Time IDIoT---DoH!!!
which one offers a better ride and are both on stock shocks?
Originally posted by JZ
Well, I have the Comptechs and am going to buy the HRs to even out my drop. The rake look just plain old sucks.
You wanna buy my Comptechs?
how many miles do you have on yours? how long have you had them on? how much?
what's a rake? post apicture if u can
MrHeeltoe
20
02-23-2023 01:54 PM
emailnatec
29
09-28-2018 04:27 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
