Comptech flywheel bolts?
I'm finally deciding to put the comptech flywheel and clutch onto my car. I pieced the clutch together (bought the flywheel from thinjim, and the clutch from krisdlm) so the flywheel bolts were used. I was wondering which bolt i would have to buy, and would it be possible to use automotive grade bolts sold at the hardware store, or would it be better to use the bolts from comptech. Any of you guys know which one it would be or have pictures of it?
Which flywheel bolts are you talking about? The ones that bolt the flywheel to the crank? Or the pressure plate to the flywheel?
When I did the clutch on my Prelude I used OEM bolts. |
the ones that bolt the flywheel the crank most likely.
Did you get some from ThinJim with the flywheel? If so, just reuse them. There is not a need to replace them as far as I know. You can't use the stock OEM bolts since there's a difference in length. The one's that come with the Comptech flywheel were ARP but I don't have the specifics on the bolts.
Purchased them from Thinjim, but i wasnt sent the bolts. Would arp have the specs on the bolts?
