cold air intake
cold air intake
I was looking on ebay at the cold air intakes and was wondering about the prices,I have a 01 type s and the prices range from about $60,00 to $270.00 is there that much diff. in the cheaper ones.Do you get more out of the brand name ones or just paying for the name.
dude, not to be an ass, but there is 10 million threads on intakes, just search.
On another note, go to vibrantracing.com and get a 4" pipe, and a 4"-3" reducer to go into the throttle body and whatever filter and you'll be good to go. Dont get the cheap stuff like i did this time, you will regret it. you want the pipe to go right up to the headlight, or down in your tire well for best gains....gl
Ultra Negro
Quoted from a fluid dynamics project.
It makes scientific sense from a fluid dynamics point of view :
A bigger diameter tube allows more air to go in but at a slower speed (more cross sectional area). The air flow speed needed to make peak volumetric efficiency occurs at a higher rpm compared to a smaller diameter tube.
A longer tube creates faster air flow compared to a short tube (i.e. more pressure differential from the opening to the TB end) and peak volumetric efficiency will occur at an earlier (i.e. lower) rpm. This is why a longer CAI has an advantage in the midrange over a short ram, regardless of intake temperature differences.
Some people prefer short rams and need their powerband to be higher with bigger cams. They get around the temperature controversy by building their own short ram heat shield.
Unregistered Member
Are you serious? Proof to back up what? My opinion? Of course it's my opinion. I didn't say, "SRI are scientifically proven to be inferior to CAIs." I just gave my opinion of what was better. Like you said at the bottom of your post, it's preference.
That being said, I do firmly believe that a CAI will produce more power than a SRI. Then again, I don't have a dyno.
Nothing is wrong with a short ram intake, provide proof or don't post stuff you cannot back up.
Not saying they are all bad but they have cons. I have one on my explorer now cause there's nothing made for it. No other choice.
short ram intakes sound better, but have less performance due to sucking in the air in the engine bay, which is rather hot in our cars, especially in florida...
rcs86
08-02-2016 06:52 PM
