It is largely assumed that the CM and AASCO flywheels are the same, but I confirmed it by looking today. Comparing my dinged up AASCO on the left with the CM on the right, they are identical with the same part numbers.
The interesting thing is that they're not just from the same factory. Clutchmasters bought branded AASCO flywheels and machined off the AASCO logo lol.
Nice catch.
lol, when one looks at the FX400: 08028-HDC6-A single disc clutch kit on their website, first thing that comes to mind is - Is that an AASCO flywheel??
That second set of numbers under the AASCO part # may be a 'date code'?
Just an FYI, if you are not aware already, is that AASCO, according to fsttyms1 (post #8 & #9 on thread below), has a service that 'rebuilds' their LWFW's.
these aasco aluminum flywheels can be used with the 03 cls6 mt ecu without any issues? I hear people have issues with throwing crank sensor code while using these flywheels sometimes
Someone pointed out this thread to me. By the date codes it appears years ago CM was reselling AASCO parts.
Oddly, the CM flywheels don't even look the same anymore. The last two I got where black aluminum and had no etching on the back. With use, the friction material looses the dark tint.
Originally Posted by 619rcr
old fw FW-028-AL
date code 0619 FW-028-AL date code 0622
To the comment about the rebuilding service, the friction material can be replaced with a new bolt in piece.
Not that I'm defending Clutchmasters. I've had intermittent problems with starting when using their light flywheel and was actually considering getting AASCO. I've now gone so far as trying to shim the back in an effort to push the flywheel slightly outward.
