clutch dampener help. need answeres asap
i looked at my clutch dampener and read the thread that zeta made. im still confused as to what lines i have to connect. their two lines going into the dampener. do i connect those? im confused as shit and need help asap so i can put my car together
pics i took
what do i connect where, need help asap
pics i took
traced the lines and i connected the two lines. one of the fittings was being a bitch but after a bleeding knuckle and a scratched up arm. i got it loose. went for a drive (noting hard) and all gears engage, and no leaks. tomorrow ill beat on it a bit and bleed the lines
Whats up with RDX owners?
Go with 4. Replace all the fluid while youre at it.
I left the bracket in place so it still holds the SS line in place securely.
so after days of testing and beating the hell out of it. all shifts are strong and solid. shifting to 3rd gear at wot, never slipped or was close to slipping. with the dampener in, it would sometimes slip if i shift quick and then go wot.
ive also noticed when im slowly releasing or applying the clutch i feel some vibrations, just for a split second, but i hardly notice it now.
still need to flush and bleed the system
MrHeeltoe
20
02-23-2023 01:54 PM
SidhuSaaB
05-30-2020 12:40 AM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
