Clock light bulb 2002 Acura TL
Dealer or www.oemacuraparts.com or eBay or amazon
Thank you for the info!
Follow up in case it helps anyone:
I was not able to find a clock bulb from any source for less than the dealer ($6).
I replaced a number bulbs in my dash switches--many bulbs can be changed by pushing the switches forward through the dash panel (you may not need to take the dash panel all the way out to access a bulb) but if you do not disconnect the switch you are working on, be sure to use a non-conductive screwdriver to twist the new bulb in.
There are tiny metal filaments that wrap around the base of these light bulbs. The metal blade of the screwdriver will contact the filaments and short your new bulb for you. There are proper tools for this, but I used a plastic knife from take-out food.
Look down in the 'tags' on this page.
sure, the part number for the clock lightbulb is 35850-sz3-911. Current dealer price is $8.70.
be aware: other button style lightbulbs in the dash are different part numbers from the clock.
ImBroke (10-29-2017)
Good information here. I put in a different dash bulb, and my clock is dimmer than the climate display. Going to the dealer to get the correct bulb tomorrow.
https://www.oemacuraparts.com/auto-p...at/switch-scat
Registered Nonmember
I replaced my clock light. put everything back together and then a couple of other lights went out. I ended up replacing all dash lights with LEDs since it was cheaper than chasing down incandescent bulb failures repeatedly
https://www.oemacuraparts.com/auto-p...er=35850sz3911
