CL-S 6M stumbling between 2 and 3k RPM?
Have had my '03 CL-S 6M for about 6 months, and have noticed the engine stumbles significantly between 2000 -3000 RPM in 2nd and 3rd... Dealer says it's normall..
Comments"?
Cheers
Jim
Comments"?
Cheers
Jim
Comments"?
Cheers
Jim
Comments"?
Cheers
Jim
Thanks for the replies!
Since the car has less than 10000 miles, plugs should not be an issue...
I should have indicated iin the first post that the stumbling occurs after the clutch is engaged and the car is accelerating thru 2000 - 3000 RPM...
FWIW, the stumbling does not affect acceleration, but it is noticeable and consistent...
Does anyone else have the same "issue"?![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
Thanks, Guys (and Ladies!
Jim
![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
Jim
drop em like its hot
yea it def does not sound normal... i guess the only thing i could suggest is check the tranny oil level...
hope you get it addressed and fixed.
My car does the same thing except its an auto.....Only during slow acceleration does my car judder between those rpms...it almost feels like my engines just gonnna fall out....PAA said they dont know what im talking about, obviously when i bring the car in the judder doesnt happen when they test drive it.. and they said its not the tranny
I have experienced similar things, and at when I shift to the next gear it seems like I didn't have the gear engaged all the way, like it was barely in gear. I would try to see if your making sure it goes in all the way. Also, is this a constant or intermittant problem?
ex 6 Speed owner :(
Mine has never done that... always super smooth. However in the mornings at the end of its warmup cycle when switching from open loop into closed loop mode it will stumble slighty while cruising between 2,ooo-3,ooo rpm. But that happens only once. Is it doing it consistently?
Something else to consider. The dual-mass flywheel/clutch can make the car feel like it's stumbling at low RPMs just off throttle; kind of a lunging and/or stumbling sensation.
Mine just started doing that a few weeks ago...I now have 50k
yah .. my 03-CLS6 (16,000 miles) does it too .. lower gears .. take your foot off the gas .. and it will jerk 3 times on its own (without touching the clutch) .. then reapply pressure on the gas . .and it will jerk 3 more times ... dealer says this is 'normal' .. and my 'stalls' for about 2 secondds every time it comes to operating temp .. dealer won't even look at this .. even though it does it every time it is cold .. welcome to Acura crappy service
If its that 'initial' bog - floor the gas in 2nd or 3rd when the RPM is at 2K... it will 'bog' or 'hesitate' for a second or two.... that can be fixed by adjusting the TPS.
Jimmbbo
Do you have your AC on when this happens? I notice the same stumble, but only when the AC is on. Dealer claims it's normal too.
Censored User
Location: Miami - just one day, I would like to drive without getting cut off!
Not sure if its the same problem but, I had some some herky jerky movements when my O2 sensor wasn't connected.
I've got a slight vibration from the engine on my 6spd when cruising on the highway at about 2900-3000 rpm. I've always attributed this to not varying the rpms enough on the initial engine break in, but maybe it's normal
Originally Posted by greenmonster
I've got a slight vibration from the engine on my 6spd when cruising on the highway at about 2900-3000 rpm. I've always attributed this to not varying the rpms enough on the initial engine break in, but maybe it's normal ![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
Originally Posted by fuzzy02CLS
Yes my car does this alot when i'm stuck in traffic.
Jimmbbo
Jimmbbo
Haven't checked to see if it only ocurs with the AC on... Will have to check that out...
It does, however occur consistently, most noticeable in 2nd and 3rd gears...
Cheers!
Jim
DerrickW
11-15-2015 05:52 PM
RSpyder
09-30-2015 12:46 AM
