Changing Oil
Old Mar 8, 2003 | 07:53 AM
Mr Zipps's Avatar
Changing Oil
I use Mobil Super Synthetic for only 4k now. I want to switch over to Valvoline cause I heard it was better. Can I do that?
Also I still have a botle of Mobil left can I mix them.
Old Mar 8, 2003 | 08:41 AM
dfv3.2CL-S's Avatar
No problem with the mix. I frequently use the Valvoline brand and it does a good job.
Old Mar 8, 2003 | 09:02 AM
CO-CL-S's Avatar
Which Valvoline are you switching to? I'd let leave the Mobile 1 in until 7-10,000 miles (it is a really good oil). YMMV
Old Mar 8, 2003 | 12:55 PM
Mr Zipps's Avatar
Im switching to Valvoline Synthetic.
So can i use 1 bootle of the mobil and the rest Valvoline..
Old Mar 8, 2003 | 07:56 PM
mr. big's Avatar
mobile 1 doenst make 5w20....Why the hell are u using it?
Old Mar 8, 2003 | 08:54 PM
2Sxy4YoMama's Avatar
Just call me DADDY!!!
The oil does not have to be 5w20. Why in the hell are u using 5w20?
Old Mar 8, 2003 | 11:43 PM
CL22's Avatar
Should we use 5w30 as the manual states, or should we use 10w30? Whats the diff between 30/40?
Old Mar 9, 2003 | 04:42 PM
dfv3.2CL-S's Avatar
I dont know why you would use 5W-20 that grade is to thin for hot areas such as Texas and southern states. I use 10w-30 synthetic and sometimes 5w-40 Valvoline synthetic.
Old Mar 9, 2003 | 05:19 PM
Beelzebub's Avatar
I noticed that too, The oil cap in the engine says 5w-20 but the manual says 5w-30. I'm not sure which one to use either.
Old Mar 9, 2003 | 05:39 PM
1killercls's Avatar
GEEZER
5/20 winter and 5/30 summer...Fuck the cap and manual.:pfawk:
Old Mar 9, 2003 | 08:05 PM
CL22's Avatar
So then we should stick w/ 10w30? I'm down in Houston, TX and it never reaches below 20degs..
Old Mar 9, 2003 | 09:36 PM
fender4's Avatar
read up here
http://www.desertsundirectsales.com/ford5w20.htm
http://www.unofficialbmw.com/all/misc/all_oilfaq.html
Old Mar 10, 2003 | 01:42 AM
CL22's Avatar
Hmm..lotta reading, especially the second link. Soo..which one to use? :P
Really...which one to use?
Old Mar 10, 2003 | 08:10 AM
tdtsai's Avatar
Honda Motors specifies all their 2003 models to use 5w-20. The only reason is to increase the mileage of their cars, so it looks good on paper to the Feds. However, this is done at the expense of the life span of the engines. I don't see how you can get adequate protection in the summer in Texas, Arizona, etc. The increasd wear and tear will not show up immediately. The susequent owners are the ones will pay for it
Old Mar 10, 2003 | 09:00 AM
fender4's Avatar
You have to pick what's best for you,, I use Amsoil with their filter,,, I also sell it so I can get it wholesale,,, I did a test on my car,,, I went 10k miles on Amsoil and then sent it to the lab,,, results came back very positive,,, they said just change the filter and keep the oil in there. This was enough data for me to change oil every 10k but I still change the filter every 5k. Note filters are very much different, cost doesn't mean your getting a good filter,, read here,,
http://www.ntpog.org/reviews/filters/filters.shtml
I am from the old school of changing oil every 3k soooo this 10k thing is new to me but seems to be working out,,, note I drive 90-100 miles daily, mostly highway,, Also Amsoil is the only Co. thats tests and promotes extended oil changes,,
more fun reading here,,,
http://www.amsoil.com/performancetests/sequence_3f.htm
Also mobil1 is very good, but they want you to change every 3k,, ???? they know how to make alot of money,,,
I'm a Aeronautical Engineer with a failure analysis back ground, I work with all types of labs soooo the above type of test are very common to me,,, some on this board will say they are biased when they are run by amsoil,,, ok ASTM is ASTM,,,
mada51589
Jan 9, 2025 04:40 PM
Laoch
1G RL (1996-2004)
Oct 2, 2015 03:27 PM
robm
Sep 18, 2015 07:53 AM
datadr
Sep 12, 2015 09:12 PM
Aleax
Sep 11, 2015 11:31 AM
