Changed my plugs... and WOW!!
Originally Posted by allmotor_2000
If you are a true die-hard car person who wants the best in performance at all times... I'd say change the plugs at 15K for NA engines and 7.5K for FI engines.
Originally Posted by F900
Guys ..... I saw the question asked but never answered ...How often should you change your sparkplugs. ? And should i go with DENSO IK22's for a stock CLS
The IK22s are 3 steps colder than the stock plugs. I'd go with IK20s if you aren't boosted.
I agree with MrSteve. I purchased a set of Denso IK20 off ebay a couple of weeks ago for about $45 for my N/A '02 TL-S.
I change my plugs every 20k miles which is probably a little too ofter. But I like tinkering so it gives me something to do.
Thanks, can i ask are IK22s better plugs then the current OEM plugs in there now, and if they are how so..also can i expect a slight increase is MPG if i go with these plugs ?
I am going to do a valve adjustment soon as well. It's chattering a little... I have heard the exhaust valves get a little loose on these motors with some mileage...
Beyond that, I'll check the PCV valve and maybe tune the car on the dyno again.
you mean the bolts? also my cars runnin funny i bet i need new wires.. how much did u pay for yours?
any thoughts on which plugs i should run?
99.5% of the time my car runs n/a, the other .5% w/ nitrous. should i still run colder range plugs?
my car has been running pretty rough on startup lately and i think it's time to get rid of the zex plugs and go w/ some iridiums.
take off your intake manafold and clean it out along with the EGR port with some carb cleaner - that solved the rough idle in my car 100%. My EGR port was nearly all the way clogged up with carbon
Run the IK20s or IK22s.
Remember, 90% of the time with the SC the bypass valve is open so we aren't seeing boost and I never once had a start up issue with the SC'ed car while using the IK22s. (With the UniChip I did though).
Originally Posted by chriskh
Maybe this was answered already but would would it be safe (and effective) to install the IK20's in a n/a type-s straight out of the box or should they be gapped?
Originally Posted by CBR1100XX
I thought these were 100,000 plugs? How many miles are you guys thinking is the right time?
Originally Posted by Johnny Rad
Why not stay stock for replacements?
ou sig - I appreciate the clarification!
Would it be a simple replacement for a non-mechanically inclined person? Or, better to just have a "professional" slip them in?
mada51589
Jan 9, 2025 04:40 PM
