CD stuck
CD stuck
So I'd just stocked up on a bunch of new cd's to listen to on my 16 hour round-trip Memorial weekend drive ... on the way up, listening was great. But on the way home, tried to insert a new cd & it got stuck. Had to manually pull it out. After that, couldn't get the changer to load. I was able to get two cd's to eject, but then nothing else worked -- not play/load/eject etc. Just get an error message Er-E1. "See Acura dealer". Radio & tape still work.
Anyone have any ideas what might've happened & how I might fix it w/out paying them an arm & a leg?
thanks.
thanks.
Did you use burned CD's w/labels on them? The labeled CD's are a bit thicker and get stuck in the changer. I'm sure they will have to take the radio apart to fix the jam... More than likely it will be cheaper to buy a new one.
Lives On BOOST
Originally Posted by ernie01acura
heres a fix, get rid of that head unit and get an aftermarket one, itll be much better
OG 3.x^7 rawr
I have had this happen to me a few times. Try this out. Take your index finger and push the slit where the CD goes into. Then hit eject. For some odd reason, this has been my fix for the stupid error message. The CD should come out and resume back to normal operation.
ABP-KBP-CBP & ME
Originally Posted by m733l
try to reset it by pulling the fuse or the battery cable. get the code first.
I'm willing to bet he stuck some burned CDs in his changer. At any rate he could have saved his CDs without having to rip them out of the unit. He may have further damaged the HU by ripping the CDs out. I had the exact same issue with my HU--in fact I started a thread about it a long time ago. It took a series of turning the car off and on daily when it finally decided to just eject all of the CDs on its own. That was nearly a year ago and I haven't had any problems since then.
-AZ BOSTON meet 3/15-
Im having the same problem on mine also, Im about to dump it for an after-market. I usually keep pressing ''CD'' or ''EJECT'' buttoms so many times until it spits out the cd or starts playing.....
try to reset it by pulling the fuse or the battery cable. get the code first..
I think something's wrong w/ my electrical generally; my SRS light stays on, the drivers seat won't recline, and now this ....
Oh, and no, I think all the cd's in there were manufactured but I have used burned cds in the past w/ no problem.
thanks; any more ideas welcomed.
check ur manual for all the fuse locations. there is one under the hood and i believe there is a "radio/clock fuse" on either pass or driver side panel. if you are having prob with electrical i would just pull the batt cables and reset the whole car. pull it and let it sit for 15 min and put it back then see what happens...
I tried pulling the fuse yesterday. it did then eject one cd (I'm not sure if there are any more left in there) and the door did shut; but I still can't load or eject or play. Whenever I turn on the car it sounds like it's trying to change cd's or something but it's not working.
I'll try the battery bit & if not I guess I have to take it in. If they pull the cd's out with a tweezer, those cd's are gone, I'm guessing, right?
I thought the bose systems in the cl's were pretty top quality. why would aftermarket be better?
thanks.
oh, and fyi, i'm a she, not a he.
thanks.
SidhuSaaB
05-30-2020 12:40 AM
