can sb pls help with seaform
OK, i have seafoamed my car like twice but I dont remenber which port i used.
Both times I did it, i used a printed a picture of the the DIY and the one with the red circle around the "VAc port" recommended hose on the TB.
But now the pic is not available on the DIY. (here).
So i wud appreciate sb sending me or posting a pic to the TB VAC port hose 4 so i can seafoam this 3.2.![Roll Eyes](https://acurazine.com/forums/images/smilies/rolleyes.gif)
Thanks in advance.
Thanks in advance.
lowrd on tein CS biatch
use the port in the throttle body. take the line that goes into/out of the throttle body facing the front of the car OFF. plug it by w/e means. attach another hose to that same port and then suck the seafoam up that way.
I personally did it this way and dumped the seafoam into a CLEAR container so you can see clearly how much fluid you've sucked up.
Mugen TSX
Eastern Canada
09-16-2015 09:52 PM
Mugen TSX
Eastern Canada
09-01-2015 11:11 PM
Mugen TSX
Eastern Canada
09-01-2015 11:05 PM
