Can 2001-2002 driving lights be put into a 2003?
Can 2001-2002 driving lights be put into a 2003? If so what would have to be done? Has anyone here done that mod?
Originally Posted by BEETROOT
yes, you just swap out the plastic inserts for the road lamps and run the wiring.
Yeehaw
right, they are the same size and everything. not exactly sure how you go about the wiring...but someone will probably chime in.
you can buy them from the dealer... costs around $100 for everything I think.
but if you are gonna do that, you might as well put in some actual driving lamps/ fog lamps instead. the factory lights are just road lamps, they don't actually do anything.
The plastic lense EXTREMELY limits the amount of wattage you can run through the stock housings. The MAX I would ever run is 18 watts. That is extremely low as far as fog lamps go. Most are 55 watt halogen bulbs. If you are going for the OEM look it is very easy to swap in the '01-'02 road lamps and run the wiring. It really isn't that involved.
Yeehaw
thanks... they are some piaas I got on ebay for like 50 bucks. solitaire 001 I think was the model...
I don't have any close up pics now but I'll put some up tonight. It was a very simple install.
mada51589
05-03-2022 08:54 PM
drewdeezy03
09-03-2015 08:04 PM
