Caliper Pins - Need HELP!
Old Feb 18, 2012 | 03:58 PM
ljmushock's Avatar
Hey everyone, been a LONG time since I've been on the forums, but I'm doing the front brakes on my 2003 CL Type-S 6 speed and I have run into a snag.
After pulling the caliper apart to replace the rubber bushings and lube the caliper pins, I've realized that the pins are different. I have no idea which one is which and the Acura dealership, parts stores, and online diagrams have been no help!
One of the pins is a brass color with several "flat" spots, almost as if the bolt is a hexagon shape, but it's a very subtle difference. The other pin is a grayish color and appears to be completely round. Other than that difference, the pins are the exact same length and very alike.
Does anyone know which pin is which? I have to pull apart the driver side since I already put it back together without realizing my mistake. Here is a picture of the two pins... The brass colored one is the one with flat ridge like things on it.
Old Feb 18, 2012 | 05:16 PM
ljmushock's Avatar
MODS: You can close this thread, however... The way I found out which is which is by remembering that I slightly stripped the lower caliper pin head when I took it out. For anyone who may have this same question, the BRASS pin is the lower pin.
Thanks guys, and sorry for the false alarm.
Old Feb 18, 2012 | 05:20 PM
StreetKA's Avatar
they should fit either way not sure though really hard to say they look identical
Old Feb 18, 2012 | 05:24 PM
ljmushock's Avatar
Yep they look identical, but... After running my fingers down the shaft "thats what she said", I noticed that the brass bolt has flat ridges on it and is definitely slightly different. I'm sure I'd be OK just using them either way but I wanted to be sure since I had the time.
Maybe someone in the future will find this thread and have themselves an answer. Oh well.
Old Feb 18, 2012 | 05:34 PM
StreetKA's Avatar
on the shaft thing
Old Feb 18, 2012 | 05:38 PM
#13 and 18 on the link below have two different part #'s; however, like you stated, the diagram does not clearly differentiate.
http://www.acuraoemparts.com/delray/...All&vinsrch=no
Jul 16, 2017 07:33 AM
copmagnet82
4G TL Problems & Fixes
Jun 29, 2016 08:09 AM
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
xsilverhawkx
Sep 28, 2015 06:51 PM
