CAI vibration or Header leak?
I just got some body work done to my CL. Got into a minor accident, the work looks great. But when I got it back I noticed my car sounds different.
The CAI sounds like it vibrates a little when I start to accelerate. Instead of sounding nice like it used to, its sounds a little deeper and louder with some vibration. Its hard to describe but I know it doesn't sound the same.
Could the body shop have done something to screw it up? They were working on the rear bumper!
I also have the old OBX headers, and they've almost completely chipped away. How can I tell if they have a crack?
Any other ideas? I guess I'll check out the cai and tighten everything up first. If that doesn't make a difference I am not sure what I can do.
In the Mid-South meow
The only thing I can think of is if they were working on the rear they had to unbolt the exhaust and maybe they didn't tighten the b-pipe to cat bolts all the way? Or the cat to header a-pipe?
so i just went under the car and its def not the cai.
it sounds like its coming from right in front of the cat where there is a flexible pipe that eventually leads to the headers. im not sure what its called...
should i try to tighten the bolts securing that pipe?
i have extended warranty, should i just bring it in to paa? how much is the deductible for the acura care extended warranty?
any suggestions?
any suggestions?
yeah it does go away when i reach higher speeds but im not sure if I am just drowning it out. its hard to hear with the windows closed. its a very deep sounding vibration. You can hear the air flowing and causing the rattle. I went under the car while it was on and I'm pretty sure the area i described is where its coming from
ok so def think that flex pipe is leaking. so how can i be sure.
I've heard of a couple of methods:
Incense smoke
Paper clip on string
Laser Pointer
Any others?
Incense smoke
Laser Pointer
Any others?
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
