break upgrade question...
my friend just turned my rotors and i put autozone cheap pads on...they squeek and squeel and im going crazy...they say i can upgrade to ceramics for the difference but my concerne is...if the squeek doesnt go away ill wanna go with new rotors...most likely rotora slotted...will these pads be fine for those?
Audi S4 driver
Usually its not the rotors that squeak its the pads. When you apply pressure the pads vibrate at high speeds which is what can cause squealing .. did you use the anti-squeal "DISC BRAKE QUIET" stuff when you installed them?
Audi S4 driver
I'd go to a local auto parts store and pick up a bottle of that stuff. Its usually a bright neon orange gel but I've seen it in a neon green too .. take the brakes back apart and smear some of that stuff on the backs of the pads then reinstall, it usually works. when it hardens its a rubbery substance that dampens vibrations on the pads.
mlody
12-04-2019 02:11 PM
InFaMouSLink
10-30-2015 09:43 AM
lanechanger
10-13-2015 10:56 AM
