Blitzsafe Help
I hate the Mets
Blitzsafe Help
So - My Blitzsafe adaptor came in less then 24 hours...Thanks StreetEffectz
But my issue is this - Without removing the stereo (which I was told was possible) how the hell do I fit my hand back ther:
When we were still installing CD changers in the trunk I would take a bit of tape and stick the connector to a long thin screwdriver and guide it to the port on the back of the radio .Once there I would use another thin screwdriver to gently get the connector in to the radio then it was just a matter of a stiff push and click it was in there .
Jens
Jens
Got da Internet Goin Nutz
I did it like this:
1. Feel in back of the headunit for the space where the connector plugs in. This will let you know exactly what you need to do.
2. Put the plug in between the top of the two fingers next to your thumb on your right hand. As you saw from step one you have a VERY LIMITED SPACE to work with so you will only be able to use these two fingers to plug it in.
3. Guide the plug into the whole and push it in.
This is EASIER SAID THAN DONE! It took me a good 15 minutes and 30 attempts to finally get it in the whole. Just be patient and you will eventually guide it in there. If necessary get a female to help you out, they have smaller fingers so it should be easier for them to do it.
Just remeber it is NOT difficult just a bit tedious and time consuming. It will not take as much time as pulling out the headunit though!
I hate the Mets
Looking at the picture...Do I need to remove any other pieces to get my fingers back there? I just dont see the angle to get my fingers in there
That is the only thing I took off.
Try #1 to see what you need to do. I have fairly skinny fingers so it wasn't to difficult for me.
You already removed most of it...removing the stereo is not much harder http://www.bui4ever.com/projects/pro...le_removal.htm
The Screeching Toyo's
Originally posted by civic4982
so is it like an RF modulator?
Blitzsafe adapter
Mike,
I just put mine in last week. What a pain in the a**! I finally gave up and my girlfriend said, "let me try" and did it in two tries. Thank God for small hands. I hooked up XM radio and its awesome! Sounds incredible. I bought the v1.d so I could hook up a IPOD as well.
AztecRol,
What adapter do I need to buy for the IPOD to connect to the Blitzsafe? What model IPOD do you have?
Thanks.
AztecRol,
Thanks.
Re: Blitzsafe adapter
Originally posted by johnny_2X
AztecRol,
Thanks.
AztecRol,
Thanks.
http://www.antaca.com/electronics/ID...able_for_iPod/
I also bought this Monster Charger.
http://www.antaca.com/electronics/ID...rger_for_iPod/
I have a 20GIG one, its the one that was out just before the new one came out a few months ago. The Charger wont work for the new ones!!!!!
I just ran the iCable under the center console and drilled a small hole in the bottom of the center console so the wire comes up in the center glove box!! I really should post some pics of this!!!
Re: Re: Blitzsafe adapter
Originally posted by AztecRol
I used this one from Monster Cable. It goes from you headphone jack straight to the Blitz Safe adaptor!!
I hate the Mets
Works like a charm - and I ordered my 30GB iPod today (got it shipped for $440) - And I will also do like AztecRol and hook it up in my center conolse
I hate the Mets
Originally posted by kev
Sweet...Thanks man. I'm definitely going to order the 30 gig. Where did you order yours for such a good price?
I hate the Mets
I managed to wedge my hand in from the bottom...Took about 10-15 minutes of messing around, but it is in...Now I need to by the RCA-headphone adaptor and run the wire to my center armrest console.
that bitch blitzsafe adaptor....took me 45 minutes to plug it in. i was sweating like crazy trying to get that it in. but it's in now. also purchased the ipod 10 gig. i think that's sufficient for my needs. tried it out....sounds good enough for the CL. now i just need to load all the cds i have. can anyone show me picks of how they have their ipods/mp3 players mounted. i need some ideas. i know where to hide the wires....i just need to get ideas on where to mount/place the ipod.
can one of you pros tell me the the difference between these 4 monster products in regards to quality and performance? I want to connect my ipod to my headunit via blitzsafe adapter, and want to get the best sound quality possible.
Computer Stereo Audio to Stereo Receiver Using Minijack-to-RCA Connection http://www.monstercable.com/productPage.asp?pin=432
Monster® iCable for iPod™
http://www.monstercable.com/productPage.asp?pin=1731
Interlink® Portable 400 MkII Bandwidth Balanced Stereo RCA to 1/8" Mini http://www.monstercable.com/pro_aud...Pro.asp?pin=135
Monster Standard® THX-Certified Mini to RCA Audio Interconnect Cable http://www.monstercable.com/thx/pro...HX.asp?pin=1613
I also posted this question in the AV forum.
OK, here goes. The first one you posted is your everyday monster wire, its OK. Cheapest wire and connectors they make. Look at how big the 1/8" side is!! HUGE!!! Look at the connectors on the RCA side compared to the 400 series, plastic versus metal!!!!
The second one is the one I got, it is made to used where it will be seen. It has this "snakeskin" around it, so it doesnt look so much like a wire. It also has the smallest 1/8" end on it!!!! This
is important, if you want to run this wire into your center glove box!!!
The third one you posted, 400 series, is one of the better wires and some of their best connectors that they make. It is a mid range cable and is great if you want to hook your ipod to your home stereo system. They only come in short lengths and the 1/8" side is HUGE!!! Most expensive one here too!!
The last one you posted, THX one is a new one to me. I have never seen or used this product. By looking at the price and the connectors, it is probably not as good as the first one you posted, the 200 series one. It does have a small connector on it and will do the job!!
It all depends on what you want to use it for and how much you wanna spend!!
Are there any cd changers that our stock head unit will actually control? I dont want just the line in souns I want it to control it alswo like to display the cd and track # and change songs
Moderator Alumnus
its been 4 months and it's probably dirtier! Hey Mantis - How bout them Eagles
Go Cowboys!
(I still don't know how they managed to win what 7 in a row?
If He Dies...He Dies
what about connecting a non-alpine cd changer onto the blitzsafe adaptor that uses a remote and extra display for the cd changer? will that work?
Originally posted by GoldieAlek
with this model...can you still use your CD-Changer?
http://www.acura-tl.com/forum/showth...highlight=ipod
Moderator Alumnus
wtf?
Does this guy know what hes talking about?
They even have it listed on their website that there is no blitzsafe adapter for the 6 disc changers, but I've talked to a few people, and they say this is the one. Someone please guide me in the right direction, this is the one I planned to buy.
http://www.logjamelectronics.com/blitzhonauxdmxv1.html
This is the right one, isn't it? I don't know why it says it wont work with the 6 disc in-dash changers.![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
Subject: RE: Blitzsafe Application
Date: Thu, 15 Jul 2004 16:20:29 -0500
Organization: Logjam Electronics
Hi Aaron:
I'm sorry but there are no adapters made that will work with your
factory in-dash 6-disc changer.
Sorry,
Jim
-----Original Message-----
Sent: Wednesday, July 14, 2004 11:50 AM
To: techsupport@logjamelectronics.com
Subject: Blitzsafe Application
I have a 2001 Acura CL-S.
Which blitzsafe adapter do I need to connect an auxiliary sound unit
(iPod) to my 6 disc in-dash CD changer?
Thanks!
Aaron P.
Hi Aaron:
Sorry,
Jim
Thanks!
Aaron P.
They are dead wrong nupe. Call streeteffectz and he will tell you the part number. I ordered mine from him too. streeteffectz.com
Originally Posted by mantis23
How'd you know I was a nupe?
Mine just has the aux line level in wires. Some of the
other ones have those wires as well as a female din plug
for plugging in an Alpine outboard 6 cd changer.
The model number the one with the din plug AND the aux in is
HON/ALP DMX V.1D
Good luck!!!
ivegotthenav
09-11-2015 07:51 PM
DAVERUBINO
27
05-15-2007 08:29 PM
