bigger injectors for supercharger
Old Apr 29, 2003 | 05:12 PM
types1967's Avatar
i was thinking of upgrading the injectors 1 size up what is the stock injector size?and would it help forced induction not to run lean?thanx guys please respond
Old Apr 29, 2003 | 07:13 PM
allmotor_2000's Avatar
WIth the rising-rate system that Comptech uses... you will run VERY rich when not under boost. The only way to properly do this is do some type of AIC (like scalbert is figuring out) or upgrade the injectors and program the ECU accordingly.
Old Apr 29, 2003 | 07:54 PM
scalbert's Avatar
allmotor is right, it won't work well by just running bigger injectors. The ECU would trim out the extra fuel so you would be right back where you started. So you would need a VAFC, Unichip or reprogrammed ECU.
My JBWeld is setting for my extra injector mount so I should have news in the next few days.
baelim
May 10, 2018 09:53 AM
Joe Avesyan
Sep 29, 2015 03:57 PM
Ratheruneeq
Sep 28, 2015 07:41 AM
Username 0
2G TSX Problems & Fixes
Sep 11, 2015 09:50 PM
