Best way to remove paint??
I painted various engine parts(about 5-6mths ago) and i was wondering the best way to remove the paint so they could be repainted.....what should i use and how should i do it....thanks
What type of paint did you use?
What parts/surfaces did you paint? |
I used a reg primer.....then i used a 1200 degree spray paint....i painted the battery cover, engine cover, the things that says ACURA on it(could be spark plug cover) and just some other little pieces.....
Originally posted by xxy1xx I used a reg primer.....then i used a 1200 degree spray paint....i painted the battery cover, engine cover, the things that says ACURA on it(could be spark plug cover) and just some other little pieces..... If you just want to repaint, I would lightly sand the parts, wipe down, maybe apply some primer, then repaint. Test anything you plan to do somewhere it is not noticeable first. |
reply to removing paint
use nail polish remover--works great and does not fade the plastic or harm it---let me know how it comes--joe--onedayzpay
