Base map Aem Ems V2 tune?
Is there anywhere that can do a remote tune or somehow I can get a base map for a supercharged j32a2?
Only other option is to get it towed to a shop.
Thanks in advance
Thanks in advance
7 - 8 lb S/C Pulley - AcuraZine - Acura Enthusiast Community
With that said, Karanx7 mentions below, in that thread, that AEM provides a J32 base map. I believe he's talking about the AEM EMS 30-6051, though.
Not sure if your Aem Ems V2 is the same?
Maybe send him a PM. He's the only active 2G forum member left that may be able to give you some direction / guidence.
For the tune, I can give you mine. It works well, and I can leave O2 feedback on so it will self adjust until you get it professionally tuned. Honestly though, AEM's J32 base map is not bad at all. Remember you will have to calibrate your O2 sensor (I would use an AEM wideband), as each one will be different regardless of tune. There's like an 11 part video guide on using AEMTuner on YouTube which will teach you how to tune your car perfectly.
The OP in the thread below was going to use the AEM EMS 30-6051 for his S/C'ed CL-S6; however, I don't think he ever followed through?
Good Luck!
Good Luck!
I have a 255 walboro fuel pump and
550cc injectors
Can I damage something with starting it on a base map? Without changes to the timing or anything else?
Taseen Syed (09-17-2024)
