Anyone got their Koni Yellow Rears on Lower Perch?
Does anyone out there actually have their Koni Yellow REARS on the Lower Perch?
I know mattg has the fronts on the lower perch. Anyone tried the back? Just curious if there might be issues.
And yes, I know that you must use stock springs with the lower perch or you will void your Koni warantee.
BTW, if you are curious, the difference in ride height between the upper (stock) perch and lower perch for the front and rear Koni Yellow Shocks follows:
Front Konis: 9/16 inch
Rear Konis: 1 inch
I got those numbers by measuring the distance between the perch rings on the front and rear Konis.
Thanx for feedback.
Rear Konis: 1 inch
Thanx for feedback.
i do, front and rear.
mada51589
05-03-2022 08:54 PM
jmoney2001
08-12-2019 06:23 PM
