Anyone with a bad OEM headlight ballast laying around?
Back to a MT!
I'm looking for one or two of the connectors that are attached to the OEM ballasts for doing my aftermarket change out. I want to do all the work up front so its easy when I do it. Let me know if someone has a bad ballast they are willing to sell or cut the connectors off and sell. PM me. thanks!
Back to a MT!
I could just cut off the old connectors from my ballasts which still mostly work, but once I cut them off and if I screw something up, then well I'm screwed lol. I figured if I get the connectors from a set of bad ballasts I can solder on the 9006 connectors which go to the new aftermarket ballasts which means all plug and play! Just me over engineering the solution...
Yea we did mine plug and play a while back, bought the 12 dollar ballast that has a headlight bulb style plug , then the male headlight style plug from O'reilly's and yea you can understand the rest.... the one you replace will be blue , not as bright.. i may just have to find a higher out put knock off ballast
