anybody from toronto or somewhere cold
T.O. Advance
when i start my car in the morning, it starts in one crank but the engine kicks really hard. it shudders (not sure if that's the best way to explain it). i've never had this with my previous vehicles. is this normal?
09 TL SH-AWD
my car takes a few more cranks to start in the last 5 days or so for some reason. maybe my battery is crapping out....
shuddering is not normal, get your mechanic to check your motor mounts, this might be due to excessive engine movement because the mounts are screwed. the suspects are usually the front and passenger side motor mounts.
I think I know what you mean - it's been ~10 degrees in the mornings here in DE for the past week or so. Car starts a little hard, yes, but unless there's a shudder running through the whole vehicle it's fine.
Does it drive ok once warmed up? Mine feels awkward until the tires warm up - feels like driving on rocks for the first couple of miles!
Does it drive ok once warmed up? Mine feels awkward until the tires warm up - feels like driving on rocks for the first couple of miles![/QUOTE]
mine's the same way.....cold tires=concrete tires
yap me in kitchener its been -15 here for the last two mornings and i gotta to start my car for at least 5 minutes untill warm enough to drive.. it also takes couple of more cranks than usual when i start it in the morning ! ITs F***** cold over here !! oh and it also idles at a higer revs too for a while!
it's normal since there isn't a lot of vaccum on a cold cold crank to energise the mounts and the engine is able to fire but it is a a lower rpm than usual due to cold causing more battery drain and engine is harder to crank
2003 CL-S 6SPD
Yeah im pretty sure its normal... my car has more or a kick to it when it starts in this cold weather. Not sure what you mean about shuddering, but the start is definately harsher.
yeh i know what you mean j187 ..im from t.o. ...as soon as the engine catches and sparks its a ROUGH SHRUG..im more than sure my mounts are NOT in great condition so this may be it, but im not sure if i got the rough shake in the summer, dont think so..then again maybe mounts are gettin killed now...when the car has been up and running it wont spark like that, rough..... cold = the culprit
rcs86
08-02-2016 06:52 PM
lanechanger
10-13-2015 10:56 AM
