Another XSpower header question
I am curious if any of you guys with the XSpower headers notice a slight wooshing sound going through your headers under hard acceleration. It is almost like you can hear the exhaust gas going through the pipes (sounds airy), and continues throughout the RPM.
I hear this with my set. I don't think this is a leak because leaks are typically pretty loud and can be heard at idle (mine are quiet at idle). If it is a leak, it has to be pretty small.
I plan to get some sea foam (or something similar) and check for leaks, but I just wanted to throw this post out in the meantime and see what others have experienced.
Well I had a previous CLS Automatic with OBX headers (not a good experience). I had to eventually get rid of them and go back to stock. This was about 4 years ago, and I now have a CLS 6speed.
MP90 uninstalled
I have a 03 6mt. i had stock headers two months ago and did a ton of header homework on the board before bying headers. I really scrutinazed the sound and performance of the stock header. the stock header also makes the same whooshing sound however it is not a pronounced. the aftermarket headers are louder. I think it sounds cool, like a turbo. mine do it most during gear changesor decelerating at high RPM.
how will you test for leaks with seafoam
6th Gear
Dito for me guys..just picked up a 2001 CL-S a few days ago with replaced headers and its annoying the sh** out of me. Thank got he gave me the stock set - i'm going to put them back on next week. Any takers on the ones that will be coming off? I just wish i knew what brand they were...hmm
I think you could use seafoam to test for leaks. because after you put it in your intake manifold using one of the vacuum lines and then turn the engine off and let it sit for 10 minutes when you start up again the exhaust fumes would be white. Which would be easy to notice if it was leaking out of the headers.
DerrickW
11-15-2015 05:52 PM
