alpha werks dyno
#41
the nameplate goes to the rear of the engine
#42
13.68 @ 102.56
Very impressive gains on just some basic mods. Good to see that there is perhaps real alternative to the Comptechs. You guys have fun at the track and post those results as well.
#44
Audi S4 driver
Did anyone notice the air\fuel ratio on his dyno ......... ?
A PERFECT 13.0 straight to 5500 RPM. Then dips to 12.0 til 6200, then jumps back up to about 13.1 or 13.2 ..........
this is much leaner than any other CL ever dynoed that I've seen .. most of the guys on the west coast that got the unichip were dynoing at 11.0:1 air fuel ratio's. And alot of us that were having problems running lean were dynoing 12.0:1 .... and with a properly tuned unichip, we should see the optimum air fuel ratio for our car, which is 13.0-13.2. It appears as if he is reaching this A\F on the stock ECU .... unless you didnt mention that you have a unichip. Very weird?
I see that your in portland oregon .. I think thats close to unichip .. you should stop by there and have them dyno your car, maybe that could give them a clue as to why some of the CL's are baseline dynoing different than others.
#45
13.2 @ 104.76mph
wouldn't i make more power if i can keep the 13.0:1 across the whole rpm range or will the ecu back the timing off? can someone explain this to me.
#46
Audi S4 driver
Well, 13.0 is the optimum A\F for our cars, but NO ONE has dynoed to that stock as of yet. Your not really supposed to. I don't get why you did?
All stock CLS's were dynoing either 11.0:1 or 12.0:1
#47
drop em like its hot
got a question... did you guys leave the stock cover for the headers on? i think its called the heat shield. i have mine off.... is that a bad thing?
#48
no, it should be off
#50
13.2 @ 104.76mph
#51
TQ > MPG
12.5:1 is the theoretical "perfect" a:f ratio for an NA car like the CL-S. 13:1 is not really that lean, not dangerously anyways. If he had a SC then yeah that'd be too lean. I find it odd that people with the Unichip had a/f's in the 12.0's because usually aftermarket chips make most of their power by leaning out the rich factory a/f ratio.
#52
Audi S4 driver
This guy however is dynoing 13.1ish stock which is where it should be for the best performance .. my question is how did he get there on base mapping. I dont think it could be from the hyper ground kit but then again I guess no one ever tested for that!?
#54
13.2 @ 104.76mph
i'll remove the hyperground system and do some testing this weekend. maybe we have another mod to consider if it's responsible for the A/F results.
#56
Best D-Line in the NFL
Location: Gainesville, Fl for college, Palm Beach Gardens, Fl at Home
Looking at that dyno, it seems as if the power drops off at 6700rpm, and then after it drops below the normal power. So with intake and alpha werks headers is it safe to say that it is better to shift at 6700rpm when racing on the track to get better established times.
#57
I was looking at the dyno also and it was done on SAE, and i have seen in the past that most people do it on STD. Which one is better? Which one shows the most power?
#58
Take it to the redline each time, otherwise you will fall out of Vtec on the shifts.
#59
It is SAE corrected.
STD's require you to see a doctor
#60
but mrsteve, what about that power loss after 6700rpm as the dyno shows, wouldnt that hurt you more than anything
#62
Doin' da crack shuffle
#63
Originally Posted by Red-CL
He could've just let off knowing he was past the peak of the curve. He had to otherwise that drop doesn't make any sense.
That's just how the CL-S dyno's:
#64
#65
13.2 @ 104.76mph
to answer the question of why my A/F ratio is 13.0:1 is simple. OEM setting is 12.5:1 and the car is actually doing what it's suppose to do. on the dyno, measuring A/F is often inaccurate because the car is not moving and cl-s are very sensitive to temperture changes. the car ecu will adjust A/F mixtures accordingly depending on the intake air temperture (IAT) and at the dyno the fan for cooling the car is inadequate. while the car spins to 105mph the fan is only blowing at 10 to 15mph which result in a hotter IAT. as you know hot or warm air is less dense in air molecule then cold air. the car will automaticly lean the mixture to compensate for thinking there is less air molecule when your on the dyno because the IAT never drops. this is the reason why my A/F ratio is at 13.0:1.
but when your driving it's a different story. the IAT will drop and cause the ecu to richen the mixture for the stock A/F of 12.5:1. so when doing any type on A/F adjustments it is very important to do it while you drive because on the dyno, depending on temperture it will always read .5 pts higher or lower.
this should answer the questions for 14.0:1 reading on car with unichip. that's why people were feeling the power and not seeing it on their dyno graph. when many of the members here dyno with this high A/F i'm guessing it was around 70 to 80 degree temperture. so technically with unichip the car is performing at the optimal A/F of 13.5.1.
#67
yes fitment they went on perfectly according to the shop, i dont know about cracking, but i hear the welds are a lot better, we will see over time.
#70
Above n Beyond
this will take some time for people to build up their trust with this company, and buy these. sure they seem great right now, but what about 1-2 yrs or more how they will handle. thats why im waiting.
not saying these are bad headers, but something seems a little fishy when ur buying them for like 400 bucks and people say they fit, perform, and hold up like the comptech ones.......but the comptechs seem to be 3x's as much as these.
#72
Comptech is the only company that has known quality headers. They can charge what they want people are still going to buy. When were given an quality alternative (so far), Comptech no longer has a monopoly over the headers for the CL/TL. Prices could possibly drop.
Even with all the R&D, I'm sure it only cost Comptech no more than $100 to make a set of headers.
#75
Audi S4 driver
And IAT alone does not determine what your AFR will be. In open loop mode its been found that your water temperature also plays a role in determining AFR
Not to mention, your information is way off and backwards. Fuel cools down the combustion chamber. Thats why cars burn up the motor when they lean out, too much air not enough fuel. If your IAT and water temp is too hot, it will richen the mixture to cool down the combustion chamber. If your IAT and water temp is colder, if will let more air in because it feels that it is safe to do so. This is the reason why half of the stock CLS's were dynoing 11.0:1 and the others were around 12.0:1.
The car will not try to maintain 12.5:1 in all conditions during open loop mode like your are saying. The only time the car tries to maintain a steady AFR is during closed loop operations, when the government mandates that the car must run at 14.7:1 for emissions regulations. The AFR during open loop is dependent on other factors. The water temp and IAT have a big impact on this, and both can change it accordingly, humidity also plays a part in it; but the car will not always try to keep it at 12.5:1 like your saying. Infact its very rare it even goes that lean on base mapping. Like I said, most stock CLS's have been found to be in the 11.0:1-12.0:1 range.
#78
13.2 @ 104.76mph
blader,
i've been working with jack at unichip for the past week to find a solution for all the problems we are having. his answer is what i posted. you can call him yourself if you think i'm lying. for you to say that know one has a 13.0:1 A/F ratio is not true. PDX3.2TL dyno his stock TL this weekend and was just as lean as i was. your also wrong about water temperture determining AFR. it doesn't, the only thing it determines is timing.
and yes, i have read every unichip thread. that is what led me to call jack.
#80
why are you trying to be funny. you didn't even know there is a flywheel in auto cl-s.
