alignment/Spec Sheet for CT Springs ??
Beware of leakage
After having my CT springs on for about a week and a half, I went to firestone to have it aligned. They told me I needed the spec sheet for my springs before they can align my car. My dilemma is, I bought my springs slightly used from a board member. Does anyone have this spec sheet they are telling me about ?
any help is appreciated
Also was going to get the alignment for life.
There is no spec sheet .The car should be aligned to factory specs .Most likely the rear camber will be out of spec after the alignment .If it does not exceed 2.0 degrees you are fine if it does a camber kit would be a good choice.
jens
jens
Beware of leakage
Well Damn, all I kept reading on here was that with the CT springs I would not need a camber because of the height, did I miss something ?
Spectacular Aroma About
The thing about needing a spec sheet for the springs doesn't make any sense to me at all. The only thing mine came with were tags that gave the load rating of each spring so you knew which side to put which spring on.
Beware of leakage
Originally posted by ChadT
I think Jens is just saying that if the camber is more than 2 degrees you need a camber kit. 2 degrees is quite a bit. The wheels would be noticeably tilted in at the top. I have had my Comptechs on for about a month and there is no way the camber in the rear is even close to 2 degrees. I do need to get it checked but I don't think the alignment is off by much. I've actually heard of a couple installs at dealers where they checked the alignment after comptech springs and it was still in spec with no alignment at all.
About the spec sheet, shocked the hell out of me, because from what I understood is that the CT's were not a "dramatic drop". I tried explaining this to the guys at firestone
![Roll Eyes](https://acurazine.com/forums/images/smilies/rolleyes.gif)
nearsighted visionary
I went to a local outfit, Les Schwab tires, quote was $70 but was only charged $45 as the rear wheels were OK at less than 1 degree from plumb and square. Alignment was performed at about 6 weeks after used CT spring install.
My Home Planet
Chopper, let us know what firestone says. I was planning on going to them for that lifetime alignment deal too. I just wanna know if they'll agree to do it to factory specs and still honor the future alignments.
MrHeeltoe
20
02-23-2023 01:54 PM
emailnatec
29
09-28-2018 04:27 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
