After market TB and TPS choices
I don't think anyone makes a TB other then Acura for this car.. You can take a stock one & send it to places to bore it out. A TPS is a TPS. OEM, or any aftermarket replacement should work fine. But will be stock settings.
You have a CLP, I think the type S TB is bigger. I'm not sure on that.
But since my new engine will need more air I will need a larger throttle body than just boring it out a couple of mm.
I can buy a cheap ebay throttle body for like 80 bucks but I have heard they are not a quaility piece.
The mustangs have nice quality throttle bodys and the tps pre 96 are simple to wire right in.
Although, How broke I am today I might end up having to get a el cheapo.
X mas is a killer over here every year.
Get a LT1 twin 58mm or larger TB
I like the look of those. But once you add a intake it will never be seen.
I imagine there also would be to much work to get it to work.
I only have 100 bucks and want to get a TB,Fuel pump,and new motor and trans mounts.
I wish I had a money strecher
09-25-2015 06:14 PM
