Adding HP to 03 CL-S 6 Speed?
Old 06-15-2016, 10:31 AM
8th Gear
mjgreencs's Avatar
Wassup Acurazine,
So I've done a lil research and I'm trying to add a little more kick to my car. So far I'm looking at new headers which I found online and also I just wanted to throw a Cat Delete/Test pipe on it regardless to the sound but unfortunately I can't seem to find one specifically made for my car. Does anybody know where I can find a Test pipe/Cat Delete that will fit? Also, I'm open to any other reasonable performance options, I don't plan on seriously racing or anything beside just some fun at the stop light every now and then. I do want my car to last and don't wanna spend hella bread on a turbo/supercharge kit.
Old 06-15-2016, 10:49 AM
3.5 psi
gnuts's Avatar
just have a shop make the pipe. flange, pipe with O2 extension, flange.
Old 06-15-2016, 11:43 AM
~HondaF1~
R J Poseidon 6's Avatar
...but beware it'll probably sound poopy
Old 06-15-2016, 12:18 PM
3.5 psi
gnuts's Avatar
make sure the headers have a bend in the rear bank primaries to clear the 6speed rear motor mount. I would forgo the test pipe and get an under drive crank pulley.
Old 06-15-2016, 02:35 PM
microracer24's Avatar
Here is a test pipe...
https://store.excelerateperformance..../i-494446.aspx
Old 06-15-2016, 02:39 PM
Is the under drive pulley still available? I found the lightweight pulleys but in the standard size
Old 06-15-2016, 02:43 PM
3.5 psi
gnuts's Avatar
you can get the pulleys from Ralco much cheaper than UR. I think they have stock and underdrive.
The following 2 users liked this post by gnuts:
03 tls nc (06-18-2016), microracer24 (06-15-2016)
Old 06-16-2016, 02:07 AM
spaceghostpurrp's Avatar
This one fits, but you need to make this one hole bigger so one of the bolts could fit
https://www.amazon.com/1998-2002-Hon...a+98+test+pipe
Old 06-16-2016, 08:05 AM
8th Gear
mjgreencs's Avatar
I also trying to figure out the best way to get the rear header bolts off I can barely fit my arm back there I thought about removing the sway bar or should I lift the car and try from beneath.
Old 06-18-2016, 11:32 PM
03 tls nc's Avatar
A test pipe for an 02 Accord V6 will fit, got one for about $25 shipped off Ebay. XS Power headers are an exact copy of Comptech and clear the 6 speed mount (Have both FYI). Under drive pulley can also be found on Ebay for pretty cheap.
johnboy1313
07-21-2021 10:19 AM
boostedorbusted
06-14-2016 07:31 AM
entropeter
04-12-2016 07:40 AM
LECKEY73
02-22-2016 01:32 PM
Palizboy
01-26-2016 07:06 PM
Quick Reply: Adding HP to 03 CL-S 6 Speed?
