Acura Emblems
kwikCLvr
When i did mine i used WD40 to get the glue off and then i ran dental floss behind each emblem to get them off...then i used TUFF STUFF to get ne remaining glue off.....all the ones on the back come off WITHOUT alighnment pins except the acura symbol...
Moderator Alumnus
Originally posted by CLSmike:
<STRONG>How did most of you take them off and what did you use also which ones come off witouht a hole in the body?</STRONG>
2) only the Acura 'A' Symbol leaves holes
3) I suggest you read my FAQ which covers this and much more.
its so ridiculously easy to get the emblems off!
you dont need to heat them up prior.
no need to use wd 40 before or after
just floss em off (sawing motion)
then use your finger and rub off the remainder
use soap and water if there is any left over (which will be very little)
and then wax over to protect
Powered By HONDA
i have heard using a fishing line will take them off..i have never tried before..but i think u do it slowly and it will come off without sracth the paint..
Buckle Up
Fishing line works. I used it on a Chevy Blazer but with the CL you can just pull it off. (i would not suggest it). Get some Goo Gone for glue that doesnt come off.
saberlove
03-11-2021 09:29 AM
Oakes
Wash & Wax
10-12-2015 11:17 AM
