84-1 sensory logic failure code
Anyone help me with this code? This code has disabled my traction control and abs. All after a misfire code was fixed and cleared, it threw this code. Is it a fuse? Or did a sensor take a crap? Any help would be great thanks.
Ok so I might have been a little premature on the thread. But did some searching found it could be a few sensors. Can anyone narrow it down for me with the problems I'm having
VSA is on
Traction control /!\ is on
ABS light is not on.
Traction control is off I cannot turn it on or off, also seems like only my front brakes work. Not sure if Abs is effected or not. Anyway I can reset these?
VSA is on
Na it wasn't the shop. Had my trans done last summer. I had misfire codes go off about a month or so ago and Replaced plugs and coils. Solved that problem. Cleared the misfire codes and it throws this light without me even driving it. So I'm not sure I what triggered this to go off and start acting this way.
Here is a thread that talks a little about it:
https://acurazine.com/forums/3g-tl-problems-fixes-114/84-1-sensor-logic-failure-819955/
Good Luck!
Good Luck!
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
