5hp for $5 bucks!
5hp for $5 bucks!
Okay folks, here's a tip for my fellow CL-enthusiasts.
As you all know intake air temperature greatly affects engine performance. Around a 3-5 degree increase in the charge temp effectively reduces air density by about 1%. This means the ECU puts out less fuel per declining O2 content. A very easy way to
gain a few ponies on your motor is to do the following:
(1) Buy 4 extra TB gaskets (its around $1.00 / gasket)
(2) Remove the throttle-body
(3) Re-route the throttle-body coolant hoses so that they DON'T pass through the throttle-body
(4) Replace the TB with a total of 5 gaskets (most likely the original gasket won't break)
This will drop your IAT by about 35 degrees under most circumstances... under WOT the throttle-body generally runs a tad cooler.
If you have a CAI, performance gains will be even better.
I don't have dyno-proof, but it works... if you want to take my word on it!
Your idle-air-control might act a little wierd... no check lights or anything like that. You probably won't have that 1500 RPM idle during warm-up.
Cost Drivers!!!!
I'll pass Thanks for the tip!
This won't have any risk as its not like it doesn't allow it to heat up at all... just lowering it a tad bit!
This will just complement the water-wetter and low-temp thermostat/fan-switch.
Cost Drivers!!!!
Yeah might be a "summer" mod. With temps going into the teens during the fall and winter I need all the heat i can get.
how do you re-route the TB coolant hose?
Instead of running the coolant hoses THROUGH the TB...you bypass them using a $1.00 fitting (just couple the two together).
The TB gaskets can be purchased from acuraonlineautoparts or any other wholesale OEM parts distributor.
How bout this. Reprograming the ECU to think that the ambient air temp is around 40oF all the time.
But let me ask u this. What is the perfect air/fuel ratio to achieve proper combustion and engine efficency? At idle I believe the car's ratio is 14.8 . So what would happen if the car were to generate a ratio of 15 all the time even in VTEC?
My dyno claimed that during VTEC the ratio was around 13.8 , I would guess that seems alittle RICH. What do u think?
Juker008
Juker008
Fooling the ECU to think intake air-temp is colder is going to do you more harm than good because the intake air-temp need to be cooler for the extra fuel to do anything!!
There are a couple of problem here.
First off there would not be a 35 degree drop in IAT readings. There is not enough surface area for the fast moving air to pick up that much heat. I have had my TB coolant lines bypassed for some time (no part is needed, just use the existing hoses and clamps) and have monitored the IAT value; it shows little to no difference. Maybe after sitting at idle for some time there might be a few degrees difference but at cruise and WOT situation, the rate of airflow does not allow for heat transfer through a flat surface like the TB.
Right now and before, during cruise and WOT situations, my IAT is at or near ambient. That is as good as it will get.
Secondly, even if there were a temperature delta, this would be minimal and at most 5 - 10 degree after having sat still at idle for some time. This would amount to maybe 1 - 2 HP max.
Now with that said, re-routing the TB coolant lines wouldn't hurt. It would not give anything appreciable but might slow heat soak while in the staging lanes. But when driving it will make no difference at all.
Best power is achevied in the 12.5:1 to 13.0:1 range. I would guess that our cars would make the best power closer to the 13.0:1 range. So your 13.8:1 was a bit leaner than one might want for the best power.
By fooling the ECU into thinking the temperature was cooler than it is would cause the car to run richer which would most likely hurt power.
With 5 gaskets or some thicker material for a gasket that doesn't transfer heat as much would help make the TB run cooler. Agreed that just re-routing the coolant hoses wouldn't make much of a difference!
The TB is only about 2 inches long; with airflow velocities of about 6 feet per second at WOT that leaves little time for heat transfer from the TB.
Keeping the TB cooler is good but IMO, only helps with heat soak when stopped. When at WOT there is little to no heat transfered to the air via the TB. The flow rates are too hight for the little surface area presented to the airflow.
Oppps. Sry I just checked the dyno chart and saw that in VTEC I was at 12.0 .
Is the only way to find out if leaning out the engine will produce more power, is to do it on a dyno?
Juker008
Juker008
Another way would be to use the wide band system and an accurate acceleration system such as the Vericom 3000; but now you are in the hole about $3500 total for both the wide band and the Vericom. That $3500 can buy quite a few pulls on the rollers...
http://www.vericomcomputers.com/Products.htm
How about the intake manifold then? Bigger job I suppose!
Xe- For Better Hwy Vision
scalbert,
I assume at this point adding an extra gasket or 2 under the
IMRC plate (sim to the TB mod allmotor was thinking) would yeild little to no HP increase by slightly raising volumetric capacity in the plenum.
Originally posted by xenon7
scalbert,
scalbert,
I Know man, I followed that whole thing- still looks damn good
from the pics!
I guess I was thinking more of what half of that alum plate thickness or even a 1/4 thickness in height would yeild.
very little I assume.
from the pics!
I had thought about taking my plate to a mill and cutting it down in half; then re-test. But I lost interest after the first failure.
The problem with a larger gasket is that you lose to seal at the top then. A center channel would need to be used similar to what I did with that wall down the middle.
I pulled my cover plate not to long ago to get a better view of the labrinth and I see your point in terms of sealing.
Milling that nice piece of alum might be key, but I understand the lack of intrest.
Any thoughts on increasing the distance on each of the 2 alum intake runners?
Unregistered Member
This is an old trick that Mustang owners have used for years now to advance their timing with a DIS system.
Originally posted by Tom2
No, not really. Using the proper resistor in the IAT connector lead will "fool" the ECU into thinking the temperature is cooler than it is and the ECU will respond by advancing the timing, which will result in more HP.
We do NOT have a MAF, our load calculation is 95% based on the MAP and IAT; Speed Density. Alter the IAT and the perceived load will be changed. A 20% FS change in IAT value could result in a 5% - 10% in the fuel supply. Any possible gain from two to three degrees more timing would be offset by the overly rich condition.
Yes, the IAT will influence timing. But it appears that our ECU uses the ECT more for base ignition timing than the IAT. The IAT is primarily used for load calculation and subsequently fuel supply.
What works on other vehicles may not apply to others. The systems have to operate similar enough and use the same technologies for alterations to be applicable. In this case the two vehicles use significantly different load determination technologies.
I was curious about whether or not we could fool the ECU into thinking it was cooler. When I was on the dyno last December I tried out a box I made. This box had two potentiometers, one adjusted the IAT signal to the ECU and the other adjusted the MAP. Without adjusting the MAP signal and dropping the IAT reading thirty degrees the fuel trim adjusted about 2.5% - 3%. I then used the other pot to bring it back.
On the dyno I was never able to gain power. The best I could achieve was a loss of a couple HP; the worst was a loss of 25 HP. So no, our cars do not benefit from a simple IAT modification as the fueling is too dependant on it. Had I taken the time to thoroughly tune the MAP signal against the IAT then there might have been a little to gain. But in no way would a resistor in line with the IAT signal give any noticeable power; it could possibly lose power.
Originally posted by moomaster_99
Get a thicker head gasket and raise the compression on the sucker!!!
Tom2,
That is exactly what I was thinking, that by tricking the ECU into thinking that it was cooler outside, that the timing would advance.
Scalbert,
Now u stated that by tricking the ECU into thinking that it were cooler outside than it really is, would make the car run richer. But wouldn't it also advance the timing to account for the additional fuel being delivered? If so could a VAFC be able to cut the additional fuel that wants to be sent but still keep the engine timing advanced?
moomaster_99,
don't i mean a "thinner" gasket?
Juker008
Scalbert,
moomaster_99,
Juker008
What you get here is kind of a double strike against the potentials. With advanced timing come lower EGTs which is fine with the same A/F ratio. Now add more fuel to it and the burn would most likely get cooler; as you get to 12.0:1 and lower, power starts dropping off quicker than timing can give it back.
Things would be different if we did not use a speed density system; but that is what we have to work with. Yes, a VAFC could be used to correct for this and do well. But now you have to install a $300 device and tune it to gain about 5 - 7 HP between the lower seen temps and the tuned fuel curve.
I would love to see a simple solution, there just isn't one. I tried but that also did not work out. It would be nice if someone was reprogramming our ECUs and giving all the timing the engine can handle; but to date that has not occurred.
At this point I could care less about more timing, my supercharger is on the way...
Steve... you need LESS timing
By the way... let me know what the Comptech FPR sets the base-line fuel-pressure to... and what spring they have inside that thing. I got the universal one so it comes with two extra springs.
Rueruerue
02-05-2016 10:32 AM
DerrickW
11-15-2015 05:52 PM
