42+ offset?
depends on your drop, wheel width and tire size.
i have 18x7 +42 w/ a 3" drop. i rub a little bit in the back on hard corners. that's with the fenders shaved.
3" drop. damn dude. any lower your car wont be drivable anymore. and 18x7 rims are hard to find.
i get around pretty good. i know how to drive it though. ![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
I had 18X7.5 +42 with 235 rubber & CT drop, & rubbed on large dips & bumps in the road. If your not lowered 235's are fine. If you are you will rub with them. 225's seem to be ok on most roads however I heard they even scrap sometimes on extream bad road or alot of weight in the car.
still a Masshole
I have a TLS (and I'm starting to think the rear fenders are different on the CLS) and I rub with 18x7.5 with 42 offset wrapped in 225/40/18 tires. I am on stock suspension. I should note that it only happens with people in the back (although 1 person will do it).
It's Go-Time.
still a Masshole
Originally posted by GOT PSI?
The TL fenders are different on the CL. If you haven't done so already, you'll need to shave the rear fender tabs.
neuronbob
23
07-16-2019 10:48 AM
SinCityTLX
55
10-11-2015 01:20 AM
