3 Questions in One SPECIAL! !
Fell off my Rocking-Chair
Simple questions which i was hoping someone could properly answer... meaning a bit of prove and not just how u FEEL about them ![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
1) Parking/emergency brakes: Any advantages or disadvantages in always using the hand brake (or foot brake for us) when the car is parked?
I'd really like to start using them every time i'm parked but I've heard it both ways where using it all the time is suppose to help out the "regular brakes" or the pads or something
.... but its is also suppose to harm the rotors? Any truth in either?
2) Topping off gas: I always have the tendency of filling up my gas tank till the very last drop or the gas station attendant threatens me to get off his property.
I've heard topping off is somehow bad cos the gas needs "space to breathe". And that after the first click, if u keep pumping some of the gas is forced to go back in while the price keeps climbing. Anyone know whats the deal?
3)Blinking sound: Any way to make the blinking sound go away or lesser while ur turn signal is on?
I hardly leave my indicator on cos that noise drives me crazy sometimes! My sister has a Legend and a new camry and i luv how the clinking/blinking sound is hardy noticable.... or its just enough to let u know that ur indicator is on - so ur not one of those ppl who have their left turn signal on for 10 miles.![Big Grin](https://acurazine.com/forums/images/smilies/biggrin.gif)
4) Had one more but cant remember
![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
![Scratch](https://acurazine.com/forums/images/smilies/scratch.gif)
1) using the hand brake actually helps the brakes by tightening them everytime you use them. Not only that but in cold weather prevents the calipers from freezing open believe its happen to me already on another car.
2) I never top off my gas cause of the weight issue. for every gallon of gas is 8 lbs. more your driving around unneccassarily.
3) if it annoys you that much just change the relay. Some people put the ultra fast relays that make the blinking real fast.
Originally posted by kensteele
And that after the first click, if u keep pumping some of the gas is forced to go back in while the price keeps climbing: Certainly not.
![rofl](https://acurazine.com/forums/images/smilies/rofl.gif)
but thanks for ur input focker
![Grin Fawk](https://acurazine.com/forums/images/smilies/grinfawk.gif)
1 Post
1) I think using the parking brake helps keep the tranny from taking the load while parked on an incline or where a car would roll a little.
2) I always start to top off until the nearest dime, therefor it's never more than a quarter gallon. I did have one time when the auto-stop contraption on the nozzle didn't work and caused it to spill over, I did not notice any problems.
3) Every car has different "sounds". Get used to it or turn up the radio. Maybe your sister wishes her cars had turn indicators that made sounds like your CL.
![Roll Eyes](https://acurazine.com/forums/images/smilies/rolleyes.gif)
EDIT: Save even further weight by driving arround naked...thats like 4-5 pounds...AT LEAST .0001 seconds off of your quarter-mile
Buckle Up
I always use my parking brake when I park...mainly because I feel it helps save the tranny. When I park in my driveway without the brake on, my car seems to jump back but with the brake it one stays in place.
Originally posted by bkknight369
OMG you have to be kidding!!! 8 lbs...its not going to affect your 1/4 mile time...jeez
![Loser](https://acurazine.com/forums/images/smilies/loser.gif)
Retired. Not available.
Originally posted by mrdeeno
the parking/emergency brakes are DRUM brakes and are a separate system from the actual disc brakes.....
Last time I checked, the foot brake cable goes directly to the calipers on the rear disc brake
Originally posted by danny25
So the parking brake just squeezes the rear calipers against the rotor? I never knew that.
![Chuckle](https://acurazine.com/forums/images/smilies/chuckle.gif)
The hair says it all
Originally posted by SilverKnight
Umm I'm not sure if I understand you correctly.
There is no DRUM brake on my 01 CL-S
Also, they told me that putting up the handbrake does this: Have you ever parked, and then you try to put it back into drive and its hard to change gears? Well, it prevents that, so it releaves pressure on the tranny.
(excuse the typos, its late)
Moderator Alumnus
Front and rear Danny so if you want to prevent your car from being towed from the front use your emergency brakes. Last time the Sheriff towed my car they had to flat bed it cause they couldn't lift the front and tow it and they were afraid to open it
The parking brake only sets the rear brakes (mechanically too, not via hydraulics). It does not effect the front brakes at all.
EDIT:
Your transmission in park is the only thing stopping the front tires from turning.
Originally posted by shaHn78
Sounds crazy but knowing how many ppl spill gas by OVER pumping, maybe the gas companies with the pump makers came up with this solution which saves them gas and money... hell i dont know
Oh sure I probably misunderstood you...I do think there's a way to overpump and spill. But I don't think you can stand there and overpump more than about a $1 worth...that's a lot of gas on the side of your car and on the ground...and the smell of gasoline.
![EEK!](https://acurazine.com/forums/images/smilies/eek.gif)
Still trolling
EDIT:
EDIT:
1 Post
Someone check the specs section of the manual or helms, please. I am confident they are drum parking brakes.
Moderator Alumnus
it's not listed on the website.
It's 4 wheel disc. It does not have drum brakes. You can see the rear rotor through the wheel. If it was drum you would be able to see the drum.
They are two totally different types of braking systems.
DRUM
![](http://www.neovenator.com/cars/mustang/images/mustang_old_drum.jpg)
![](http://www.sullivantire.com/autoservice/images/brakes_diagramd.gif)
DISC
![](http://www.metromustang.com/Image/Disc_Brakes.jpg)
![](http://www.sullivantire.com/autoservice/images/brakes_diagramb.gif)
1 Post
the DRUMS i'm talking about is for the parking brake mechanism ONLY.
learn to figure out what we are arguing about before posting.
Moderator Alumnus
what part of PARKING brake did you not understand?
NO IT DOES NOT HAVE DRUM BRAKES, OF ANY SORT.
It has no DRUMS of any sort on the rear of the car.
DRUM brakes get their name from the DRUM they have. There is no DRUM on the CLS. It's a mechanical DISC parking brake. Here look at these diagrams.
http://www.v8sho.com/SHO/rearbrakes.html
*note the mechnical lever on the DISC brake
Anyway, I'm not going to arg with you. You are welcome to think whatever you want. What do I know....
Originally posted by louisn
I think Mrdeeno is right--4 wheel discs with an integrated drum parking brake going to the back wheels.
Also, its not a good idea to top off the tank, especially in warm weather, because liquids expand as they heat. If your tank is 100% full, where's the expansion room?
1 Post
:P
i'm sure the specs are either in the driver's manual or the helms or both. i'd scan it or quote it but i'm in brazil and my car and all the manuals and stuff is in PA.
Moderator Alumnus
you were so sure of yourself just 3 posts ago, weren't you?
:P
:P
So they built drums into the rotors eh?
Kind ass backwards if you ask me...
You haven't proven anything, so SHADDUP!
Easy enough, find the part # for the brake shoes. And I'll shaddup. And DONT post the brake PADS part #.
EDIT:
WERD, I'll shaddup.
It does have a "DRUM BACKING PLATE"
I stand corrected.
this is what I always thought
oh, and check out the rear wheels, you can see the drum backing plate.
I'm still sure.
Kind ass backwards if you ask me...![Roll Eyes](https://acurazine.com/forums/images/smilies/rolleyes.gif)
EDIT:
WERD, I'll shaddup.
I stand corrected.
I'm still sure.
EDIT:
WERD, I'll shaddup.
I stand corrected.
Originally posted by Red-CL
Gas only weighs 6.1 Lbs per gallon. Water weighs 8 Lbs per gallon.Just my
j/k j/k
navtool.com
31
11-16-2015 08:30 PM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
navtool.com
09-25-2015 05:15 PM
