3.5L 1/4 Mile Track Results (Live Report)
#41
some real world temp differences,
in august i ran a 14.32 @ 98.09 in high 70 degree weather
but in october i ran a 14.16 @ 99.11 in 50 degree weather
passenger seat, rear seats removed, trunk stripped for the 14.32 run.
full interior w/ trunk stripped for the 14.16 run, also backet it up w/ a 14.17
looks to me the biggest advantage typeR has is the torque down low, not so much top end power. as my fastest trap speed is a 99.77 also.
#42
Floyd Mayweather Jr.
Originally posted by Zapata
JimCol,
Did you see how much humidity he's driving in???
Money is NOT a variable. Weather is..............
JimCol,
#43
For day-to-day driving, that broadband torque increase sure comes in handy. It also is a kind of "back-assward" fix for the too-tall 4th gear.
There may also be more room for top end improvement TOO...
The rod ratio does an nice job of punching the air flow up through the lower- and mid-range RPMs. The "original" 3.5L-XXX???XXX was reported to have "mild" headwork (port, polish, etc). It's possible to start pulling too much air velocity for the "current" setup (exactly where and how is speculation). IOW, a little upper-end massaging might keep the low-end torque up while extending the torque further up the rev range...
The torque gain across the whole band in the 3.5L vs. 3.2L dyno is pretty “fat.”
Finally, I think the wheels are stock… Perhaps Type-R will comment on his exact setup.
#44
full interior w/ trunk stripped for the 14.16 run, also backed it up w/ a 14.17
The consistency of the 14.16 & 14.17 ETs couldn't hurt for making a point regarding temps. (I'll wager it wasn't too humid either - hey?)
Is everything that changed noted in your comment?
EDIT: Based on your going to different tracks (your comment below), the differences could be minor or huge... (Ice rink vs. sticky trap surface and altitude issues)...
#45
well, it was a different track :o
#48
Erase everything I just said about your comparison runs. Adding-in the different track (and track surface, etc) as one or more variables, just makes for more speculation...
#49
agreed, but there is no denying my 99+ mph trap speeds.
#51
ericL heres another run for you to analize:good 1/4 compared to best 1/8th the 1/8th was done at around 65*
.661 *** .591
2.138 *** 2.098
6.023 *** 5.889
9.127 *** 8.969
@78.89 *** @79.35
11.824 ****
14.061 ****
@ 100.21
at the 60' foot i am .050 behind my best...at the 1/8th im still .050 behind...however at the 1000' im only .020 and finish the 1/4 with that same defecite obviously i was making more power on that run ...im thinking when i get my 50* weather and my SSR competition wheels a 13.8** @ 103-4 do you think this sounds unreasonable?
.661 *** .591
2.138 *** 2.098
6.023 *** 5.889
9.127 *** 8.969
@78.89 *** @79.35
11.824 ****
14.061 ****
@ 100.21
asahrts
09-04-2015 05:55 PM
Mugen TSX
Eastern Canada
09-01-2015 11:11 PM
