2003 CL 6 speed in a 2004 Odyssey
Old 08-07-2017, 09:33 PM
  #281
johnboy1313's Avatar
Originally Posted by cu2wagon
Are you going to plastic weld it together or coat it somehow to make it look less Frankenconsole? Or just love it for it's imperfections?
I'd like to make it look finished. I think I can cover most of it with the door pocket and maybe use some JB weld and steel wool to fill in the voids. Maybe cover it with some resin or something. I'm even worse at upholstery than I am at fabrication.
Old 08-07-2017, 09:43 PM
  #282
cu2wagon's Avatar
Received 7,772 Likes on 5,045 Posts
Maybe just filler and then Super-77 some thick vinyl or even leather over it? If only you had leather seats to match...
Old 08-07-2017, 09:44 PM
  #283
cu2wagon's Avatar
Looks awesome by the way. You're really killing it!
johnboy1313 (08-08-2017)
Old 08-08-2017, 02:06 PM
  #284
Well, she's all legal. Title, plates, and insurance added today. I plan to drive it to work tomorrow.
Have I mentioned how much fun it is to drive? Holy sh!t.
Old 08-08-2017, 02:14 PM
  #285
rockstar143's Avatar
Received 19,996 Likes on 14,504 Posts
Really?
Old 08-08-2017, 02:30 PM
  #286
Jakes_tl's Avatar
everything running good now?
Old 08-08-2017, 02:34 PM
  #287
yes, real gud
Old 08-08-2017, 02:44 PM
  #288
It runs great. The only problem I have is that the 4th gear syncro is bad. I get a little grind if I don't double clutch 4th gear. I wish I had opened the trans up while I had it out and taken a look at things, but it's too late now. I'm not gonna drop the trans again for a while if I can help it. Maybe I'll address it the next time I do the clutch.
Old 08-08-2017, 03:09 PM
  #289
Latent car nut
horseshoez's Avatar
Received 2,019 Likes on 1,416 Posts
I haven't read this entire thread; have you tried replacing the MTF with ACDelco Synchromesh Friction Modified? I had a slight grind in third when I bought my car and the Synchromesh (Friction Modified) fixed the issue immediately.
Old 08-09-2017, 09:35 AM
  #290
I've read where that stuff has led to more problems in the long run.
Old 08-09-2017, 09:39 AM
  #291
Received 8,714 Likes on 6,721 Posts
Really? I haven't read that anywhere (on these forums)
Old 08-09-2017, 10:16 AM
  #292
Jakes_tl's Avatar
I also recommend ACDelco Synchromesh Friction Modified fluid, never heard anyone having issues. I've ran it in my cars without any issues.
  #293
That's good enough for me. Just ordered some. I'll report back when I get it in.
Old 08-09-2017, 11:40 AM
  #294
Latent car nut
horseshoez's Avatar
As others have indicated, quite the contrary really; some folks have been to the point of having the synchros replaced, or worse, the tranny rebuilt when they finally tried ACDelco Synchromesh Friction Modified (beware, there is also a non-Friction Modified version of Synchromesh as well, do NOT use that version). Funny thing, all follow up reports, even after an additional 100,000+ miles indicate the tranny is still shifting flawlessly (assuming a MTF drain/refill every 30,000 miles).
johnboy1313 (08-09-2017)
Old 08-09-2017, 11:49 AM
  #295
I only ordered two quarts. I have a partial quart of Honda MTF leftover from a couple weeks ago. Do you all think it's OK to use two quarts of one type of fluid and a little bit of another?
Old 08-09-2017, 11:54 AM
  #296
Latent car nut
horseshoez's Avatar
Well, I suppose only ten ounces of Honda MTF is better than a full fill of Honda MTF. That said, were it me I'd buy a third quart of Synchromesh and use the Honda MTF to lubricate squeaky door hinges, pour into a hive of ground wasps, or even use it as a cure for dishpan hands; I just wouldn't put it in a Honda manual transmission.
Old 08-09-2017, 11:56 AM
  #297
Received 16,266 Likes on 11,974 Posts
what an awesome build!!!!
Old 08-09-2017, 11:57 AM
  #298
Latent car nut
horseshoez's Avatar
Couldn't agree more.
Old 08-09-2017, 12:49 PM
  #299
I went ahead and ordered a third quart. No point in going cheap now.
horseshoez (08-09-2017)
Old 08-18-2017, 05:33 PM
  #300
No luck. It's still grinding. It's not terrible but it's not any better. Dang.
Old 08-18-2017, 06:14 PM
  #301
Is it supposed to work right away or does it take some time. I just changed the fluid this afternoon and have only put a couple miles on it. Only got to 4th gear three times.
Old 08-18-2017, 07:28 PM
  #302
Latent car nut
horseshoez's Avatar
Crap! Serious bummer.
When I put the Synchromesh in mine it transformed the transmission in like the first 100 yards; not *quite* "right away", but pretty darn close.
Old 08-18-2017, 08:09 PM
  #303
Crap for real.
Old 08-18-2017, 08:52 PM
  #304
Received 1,831 Likes on 1,474 Posts
Mainshaft Assembly Clearance Inspection begins on page 13-35 in the Helms Manual.
There is a note that states: If replacement is required, always replace the synchro sleeve and hub as a set.
Does that mean you would have to purchase #3 ($407.73) Gear Set Counter-shaft Second; to get the sychros you need, and possibly #6 ($78.50) Gear, Counter-shaft Forth to remedy your issue?
https://www.acuraoemparts.com/auto-p...ntershaft-scat
Old 08-18-2017, 08:54 PM
  #305
No, it means we skip 4th gear or double clutch.
zeta (08-18-2017)
Old 08-19-2017, 03:14 AM
  #306
01acls's Avatar
You might want to try XADO EX120 for manual transmissions. It may be the best $20 you'll ever spend.
Old 08-19-2017, 04:35 AM
  #307
TacoBello's Avatar
Received 4,416 Likes on 3,322 Posts
No, don't mix them. It's a waste of the GMSMFM. You now have diluted fluid which really isn't doing what it was intended to do. It really is an all or nothing fluid change. Also, are you sure the viscosities are the same?
you might not be able to fix your problem with just a straight fluid change, but it's a cheap enough potential fix to try.
Old 08-20-2017, 11:09 AM
  #308
i bought three quarts of GMSMFM. It didn't help at all. It's crazy because it's just the slightest grind. It's disappointing more than anything really. I'm not pulling that trans again right now after the fight I had putting it in.
Old 09-24-2018, 11:05 AM
  #309
Back at it guys. I'm almost certain the engine and trans are coming out again. After all I've done, my wife isn't that impressed. She doesn't want to drive a second gen Odyssey for the rest of her life, no matter how awesome it is. I shoulda jumped on a chance to get cheap parts for the trans but I didn't, like a chump, so I'm going to be buying new. I'm going to open the trans up, like I should have before I installed it, to examine the damage before I order any parts, then I'm gonna rebuild it myself. I might find a different engine too. I haven't made up my mind if I want more power or better fuel economy. Either way, I'm guessing the 3.2L is gonna go. Feel free to post all the advice you've got regarding building a good motor.
I'll make sure to take some pictures.
Old 09-24-2018, 11:26 AM
  #310
Unregistered Member
Karanx7's Avatar
Doing a manual trans rebuild with pictures would be awesome!
Is there something wrong with the engine? Why rebuild or replace it? Like you said, it doesn't seem like your wife would be impressed by a different engine.
Old 09-24-2018, 11:31 AM
  #311
This isn't about the wife anymore.
Old 09-24-2018, 01:43 PM
  #312
J35 or J37 would probably be best
or LS
Old 09-24-2018, 08:00 PM
  #313
I'm going to open the trans up, like I should have before I installed it, to examine the damage before I order any parts, then I'm gonna rebuild it myself. Feel free to post all the advice you've got regarding building a good motor.
Not sure if I've provided this already in the past; so, just an FYI.
Check out the link below for pictures of the inside of a 05 TL 6spd. On page 69 starting at post #2741 and continuing on #2742 and #2743.
https://acurazine.com/forums/3g-tl-p...718808/page69/
Then in post #2751 the banned forum member NVA-AV6 gives some 'good tips' on what to look out for when working on the MT.
Continuing on to post #2755, he shows pictures of the inside of the 03 CLS 6spd tranny.
Hopefully, as part of your preplanning those pictures will give you an idea of what 'stuff' looks like.
The following 2 users liked this post by zeta:
johnboy1313 (09-25-2018), teh CL (09-30-2018)
Old 10-03-2018, 08:29 AM
  #314
I may have spoken too soon. Sometime shortly after my last post, my wife's van gave her troubles so she switched to the shiftervan. After a week or so of driving it, she loves it. I've got to investigate an intermittent P0335 code on her van that I think is related to a broken or shorted wire in the harness somewhere. I'm hoping to find it right away and punt that van down the road. It looks like I won't be pulling the drivetrain out of the shiftervan after all.
Old 10-03-2018, 11:53 AM
  #315
cu2wagon's Avatar
Love it when a plan comes together! ATeam.gif.
Old 10-21-2018, 01:59 AM
  #316
Ackrite-TL's Avatar
Nice to have another j32 swapped odyssey. Too bad my van didn't last long as it was wrecked badly. I may try another swap again soon👍🏻
Old 10-21-2018, 02:42 AM
  #317
Null and proud of it
Midnight Mystery's Avatar
Clean egine bay... What, no reservoirs or wiring for anything?
Sorry to hear that... I always loved the Odys!!!
Old 10-23-2018, 07:36 AM
  #318
It's called a tuck, MM. You know what a tuck is, I'm sure.
Old 01-25-2019, 03:56 PM
  #319
Chris Frazee's Avatar
So I’m about to be doing a 6sp swap in an 03 Odyssey.. Do you have pics on how you mounted the clutch pedal under the dash? Also, I’m assuming the wiring is different t from 02-04 than it is the 99-01 Odyssey vans as far as green plug and using the CL harness to run the van.
Old 01-29-2019, 07:36 AM
  #320
I don't have any pics other than what is in the build thread. I took the ABS control module under the dash off and used the bolt that secures it to the firewall to locate a bracket that I made to mount the clutch pedal. The clutch was the hardest part. Good luck. It's a pretty cool vehicle when it's done. You'll enjoy it. I tried to message you but I got a message saying your inbox is full.
