2003 CL 6 speed in a 2004 Odyssey
Old 09-07-2016, 11:11 AM
  #41
johnboy1313's Avatar
Originally Posted by SykVSyx
Don't think you can use the strut bar from the CL, which would be too bad. Wonder what an Oddy would handle like with a bit of reinforcement up front. lol
The Ody's upper strut mounts are built into the firewall/cowl. It's pretty rigid already.
Old 09-07-2016, 07:02 PM
  #42
The radiator is out folks. Just like that, twelve more inches.
Old 09-07-2016, 07:17 PM
  #43
Received 8,714 Likes on 6,721 Posts
Nice hood support remove the hood?
Old 09-07-2016, 07:19 PM
  #44
haha. I'll get to it. I'm here by myself. I want to set it on towels on top of the luggage rack and strap it down.
Old 09-07-2016, 07:57 PM
  #45
cu2wagon's Avatar
Received 7,772 Likes on 5,045 Posts
Well, I instinctively wanted to call on this dreamer dreaming of a build... But then he went and actually started doing it.
Soooo.... Ghetto subbed for moar!
Good luck OP, I'm pulling for you. Let me know if you need a goat sacrificed for automotive fortune.
Old 09-07-2016, 08:09 PM
  #46
3.5 psi
gnuts's Avatar
Old 09-07-2016, 08:40 PM
  #47
Originally Posted by gnuts
holy crap. Lol.
Old 09-08-2016, 07:39 PM
  #48
If there's one thing I can't stress enough. When doing something like this, go to Harbor Freight and get the $6 can of zip ties. I think I got this one six years ago for half price because the plastic kid was broken. They are the jam. For real.
Old 09-08-2016, 07:46 PM
  #49
rockstar143's Avatar
Received 19,996 Likes on 14,504 Posts
Damn dude, that's smart AF...I never considered using it to hold stuff up like that so you know where it goes.
Old 09-08-2016, 09:04 PM
  #50
Not a whole lot to report tonight folks. Got the engine wiring and power steering disconnected and tucked outta the way. I've still got the throttle cable, exhaust, shifter cable, transmission wiring, break booster vacuum, and heater plumbing to disconnect. Not to mention the wheels, ball joints, and axles.
Old 09-09-2016, 07:19 AM
  #51
Derek
SykVSyx's Avatar
Any plans to do some sort of wire tuck at all?
Would love to see how clean the engine bay would look with minimal wiring......however, leaving it as is would be impressive enough when you pop the hood and see what's hiding under there.
Old 09-09-2016, 07:47 AM
  #52
Probably not. It seems like more work than I really care to do.
Old 09-09-2016, 07:49 AM
  #53
I don't blame you...
it's not my thing either!
Old 09-09-2016, 08:00 AM
  #54
3.5 psi
gnuts's Avatar
almost spat my coffee out!
Old 09-09-2016, 08:04 AM
  #55
Lol
Old 09-09-2016, 08:25 AM
  #56
cu2wagon's Avatar
"Would you drive that car? I'd drive that car. I'd drive that car hard. I'd drive that car so hard."
Old 09-09-2016, 10:10 AM
  #57
So, I'm at the point of ordering parts for the 3.2. I'm going to get the Gates belt kit and probably the Asin water pump. What seals should I get and what manufacturer? I'm looking at the Timken front and rear crank seals and cam seals. In a perfect world, I'd do the clutch while I've got the engine out However, I'll probably have a look at it and make the decision then. I'm hoping to not have to touch it. In fact, I will admit that I am intimidated by the special tools needed.
What else should I pay attention to while I've got the engine on the stand?
Old 09-09-2016, 10:19 AM
  #58
If it were me, I'd probably stick with Honda OEM seals
Valve adjustment, tune up, new plugs seals, valve cover gaskets, Cam and crank seals, rear and front main seals. Maybe throw some carb cleaner on the Intake manifold and clean the EGR port while it's out. New TB gasket as well.
just throwing ideas out
Old 09-09-2016, 10:36 AM
  #59
JarrettLauderdale's Avatar
The Aisin water pump actually has larger impeller blades than the OEM Yamada water pump. It's the OEM-supplier on plenty of other Honda engines, so I'd feel perfectly fine using it. In fact, I am.
Old 09-09-2016, 11:02 AM
  #60
Alright, I've located OEM Honda cam seal, front and rear crank seals (are they different from main seals? I thought they were the same thing) and an OEM water pump seal. I've got a gates timing belt set and Aisin water pump as well. I'm also looking at springing for the LUK flywheel and clutch kit, as well as, the OEM Honda clutch tools.
All in, it looks like its gonna cost around $1000
I'll take care of the valve adjustment and tune up once the motor's in place.
Old 09-09-2016, 11:07 AM
  #61
3.5 psi
gnuts's Avatar
Does the 3.2 start fine? They're pretty bulletproof engines. I would just do the basics - timing belt, water pump, valve adjustment, plugs & plug seals, clean the EGR ports and have a look at the rear main seal. Throw a light weight crank pulley on there too.
TacoBello (09-09-2016)
Old 09-09-2016, 11:10 AM
  #62
I've read to use the OEM water pump seal even if you're using another pump. Do any of you know if they'll work together for sure?
The 3.2 starts and runs great. I've only driven it slowly up the driveway because the right lower control arm is bent and the strut is broken.
Old 09-09-2016, 11:17 AM
  #63
Can't say for certain if they are the same. I thought the main seals were between the trans/engine but i'm speculating
If you're talking about the CL and the part number is 51355-S84-A00
I have a used LCA right front that I bought a while ago.
If you're talking about the Ody, then I can't help
Old 09-09-2016, 11:27 AM
  #64
I'm just going to scrap the CL when I've taken what I can from it, which will prolly be a lot. No point in throwing any money at it.
Old 09-09-2016, 11:30 AM
  #65
I went ahead and ordered the timing belt parts and seals. I'm going to hold off on the clutch and tools until I know I need it. It cut the price from $1000 to less than $200.
Old 09-09-2016, 12:23 PM
  #66
Received 1,831 Likes on 1,474 Posts
The crankshaft main seal on the timing belt side is #24 on the link below. These usually do not leak at the TB change interval; however, yours might be.
OIL PUMP - OIL STRAINER for 2003 Acura CL COUPE
The rear main seal, #20 on the link below is the main culprit for leaking, which can occur at any time. I just had mine done when the clutch was changed back in Dec2015. The mechanic stated he put some RTV on the inner seat of the oil seal case assembly before pressing the seal in helps minimize potential leakage going forward; however, that remains to be seen.
CYLINDER BLOCK - OIL PAN for 2003 Acura CL COUPE
You can usually get the best price on the Luk08-047 clutch kit and/or the Luk DMF063 between Rockauto and Amazon. The clutch kit comes with the alignment tool. There is one expensive tool that the Helms recommends to use; 07AAE-P8E-A000 Pressure Plate Compressor; however, I'm told that the PP can be installed correctly without it.
Old 09-09-2016, 12:36 PM
  #67
Neither one of your links worked for me. Both said "Page Not Found"
Old 09-09-2016, 12:42 PM
  #68
The Forum must be blocking them, sorry.
Press the link, when 'page not found' window opens, go to the address bar and delete all of the acurazine bullshit up to the acuraoemparts.com address, and it will take you there.
Old 09-09-2016, 01:08 PM
  #69
cu2wagon's Avatar
The following 2 users liked this post by cu2wagon:
johnboy1313 (09-09-2016), zeta (09-09-2016)
Old 09-10-2016, 05:22 PM
  #70
Everything is disconnected now except the motor and transmission mounts. I'm done for the night. Gonna put my tools away and hang out with the kids. Stay tuned tomorrow for pics of the freshly liberated engine and transmission.
Old 09-10-2016, 06:53 PM
  #71
I changed my mind once I got out there. No matter what anyone tells you, it is possible to pull an Odyssey motor from above.
Old 09-10-2016, 07:59 PM
  #72
That's the CL then, from above?
Old 09-10-2016, 08:40 PM
  #73
No, that's the Ody from above. I'll start stripping the CL Monday or Tuesday.
The entire engine harness came out with the engine. I'm hoping but pretty sure the CL harness will do the same.
Old 09-10-2016, 09:36 PM
  #74
cu2wagon's Avatar
Damn. You just get busy don't you?
Old 09-10-2016, 09:44 PM
  #75
3.5 psi
gnuts's Avatar
Putting in work! Nice job.
I almost put an offer on a 2003 aspec TL with a blown tyranny today because of you. I backed out becausea lack of tools, time, money, experience etc. Lol
Old 09-10-2016, 11:17 PM
  #76
Null and proud of it
Midnight Mystery's Avatar
I can't wait to see this thing chirp 3rd!!!
Old 09-11-2016, 07:33 AM
  #77
haha, lol.
me either.
Old 09-11-2016, 09:03 AM
  #78
I love this thread...
I must've misread it...I thought you said it IS impossible from above! Hence the cumfusion!
Old 09-12-2016, 07:10 PM
  #79
teh CL's Avatar
Umm... thread of the year?
Old 09-12-2016, 07:13 PM
  #80
cu2wagon's Avatar
Certainly "OTM". Might need some boost to fully become OTY.
