2001 vs 2002 steering
I just got my acid rain replacement car from Acura.
It's a 2002 and the steering has a different feeling to it .
It takes a little more effort than the 2001 more like my old GTI.
Has anyone else driven both years and noticed this
'Cooter
i know that the TL-S's have torque sensitive variable power assisted R&P steering, but i'm a bit unsure if the '02 CL-S's have it or if they're just like the '01 variable assisted R&P...if the '02 CL-S's DO have the torque sensitive steering, perhaps that's y u have the variance...at higher speeds, the steering does get quite sensitive.
'Cooter
Originally posted by bone_stock
Torque sensitive? Are you sure you don't mean speed sensitive? I've never heard of torque sensitive? I can understand varying steering sensitivites at different speeds, a la high assist at low speed and low assist at high speed. But you can get maximum torque at high speed and I don't know about you but I want my steering constant at high speed.
here's what they said bout the RSX's torque sensitive steering:
Torque-Sensitive Power Steering
A "race-car" feel was a design priority for the RSX, and thus the steering system was optimized for outstanding precision and control with a new torque-sensitive system. Compared with the Acura Integra, the RSX features a quicker steering ratio for a more nimble handling response. Steering smoothness and directional stability are enhanced with a vibration-reducing, oil-filled damper in the steering box.
The rack and pinion torque-sensitive steering system of the RSX is equipped with a new variable-capacity power steering pump, which increases fuel economy by 0.5 percent.
Tracking stability is enhanced by the high-mounted steering box, which improves toe control by using long, high-mounted tie rods to steer the vehicle.
6 speed...
Pham Alvan
03-16-2016 09:17 AM
