2 in 1 Gauges for you FI guys
Found these things on another forum I frequent http://www.spatechnique.com/dualgauges/dualgauges.htm
Since the A-Pillar mount made only has space for 2 gauges, this lets you moniter more stuff in the same space. Plus they can recall peak values and can be set to alarm you if something drops too low.
Just thought it was cool and something some of you might be interested in.
I saw those before, I think KingMotorsports carries them.
I was actually thinking about buying the Boost/Fuel psi gauge so I'd be able to run my AFR gauge in the pod, but I really like the look of the autometer gauges. The face is almost exactly the same color as the Type-S gauges.
http://www.omorimeter.com/80mm-ADCH-425-BZ-N.jpg
heres a 60mm.
http://www.omorimeter.com/aeco-225-afc-rr.jpg
^The problem with those boost gauges is that they go all the way to 25psi. No one is going to see that much boost on the J32A2 in our cars. This means that the actual range needed 0-10 psi is harder to read. I think everyone who has purchased gauges for their CL/TL has a gauge that reads no higher than 15psi.
They have an interesting website and custom gauges can be made. Cheers.
Originally Posted by ThinJim
I'll need a gauge with that range.
They have an interesting website and custom gauges can be had if you were to look; Cheers.
What compression ratio are you planning? Jesus H... 15+ psi
And no luck getting new gaskets made correct?
hey whats the deal with the axel's? any news on them? Do you know if the 6spd axels are the same as the automatic? haven't checked on that fitment requirement.
I just checked the part numbers and the driveshaft assembleys for both the 5AT and the 6MT are the same.
I haven't heard anything back from the guy having them installed in his Accord, but in addition to the Accord axle they sent out to have built, they sent one from a CL-S.
The part numbers for the OEM driveshaft assembley is:
205584 - Left
205605 - Right
Obviously there is no half-shaft in the automatic transmission model, I don't know if you wanted to beef that up too in your 6MT.
205584 - Left
205605 - Right
VOTE OUT THE BUSH REGIME
My dynotune.org (speedshop.org) gauges read up to 150 PSI. If I every want to boost that much
Digital Boost Pressure Gauges are super accurate compact. To 150 PSI boost and they even read vacuum! Available in Round or square packages and RED or Green Displays. 100% billet aluminum!
Our Price: $159.00 Item in stock!
Average rating :
205584 - Left
205605 - Right
205584 - Left
205605 - Right
Thanks for the numbers. I wonder who he used to make the axels?
http://driveshaftshop.com/HONDAPAGE.ivnu
OculiAquilae
11-19-2018 02:24 PM
BoricuaTL
04-08-2016 01:08 PM
mrkingstonvi
02-22-2016 01:53 PM
