15k Service
Best D-Line in the NFL
Location: Gainesville, Fl for college, Palm Beach Gardens, Fl at Home
15k Service
how much should it costs. Im gonna check it all off the list, not take out anything. Is it okay if i do it at about 13,000 miles. I got my last oil change at 9,126... and my tires on at about 10,500 miles. My contis have one bar showing up in the fronts and they are like new in the back, so im thinkin i should do the 15k service at 13k, so i can get my oil changed and tires roated and service all at once.
do you know what they do at the 15k service, and if i decide to do it, how much should it cost. Does my plan sound okay?
Houses Won't Depreciate?
https://www.ahm-ownerlink.com/Mainte...n&mi=15&box=ab
Services to be performed:
Replace engine oil.
Rotate tires (follow pattern on page 269 of your owner's manual.
Replace engine oil filter.
Inspect front and rear brakes.
Check parking brake adjustment.
Inspect tie rod ends, steering gear box and boots.
Inspect suspension components.
Inspect driveshaft boots.
Inspect brake hoses and lines (including ABS).
Check all fluid levels, condition of fluids, and check for leaks.
Inspect cooling system hoses and connections.
#Inspect exhaust system.
#Inspect fuel lines and connections.
# = See information on maintenance and emissions warranty, last column, page 223 of your owner's manual.
Replace engine oil.
