Will these rims fit my 07 TSX
I am looking to have fender work done will these rims fit my 07 TSX 19x8 +6 225/35/19 FRONT
19x9 +13 235/35/19 BACK
This is just so wrong in so many ways. Why would you want bigger tires and wheels on the back when the car is front wheel drive? If you insist on the staggered look, maybe buy a car that's RWD. And though they might fit, most of the tire/wheel will stick out of the wheelwell (meaning it would look too stupid to even consider)(in my opinion of course).
You need to define what you mean by "fit". Anything that's the right bolt circle, will fit over the brakes, and has a hub opening diameter that's the same or larger than the TSX should theoretically fit. The major issue I see with the wheels you have listed is the offset. OE is et55, most aftermarket wheels tend to run in the et35 (which is kind of extreme)(in my opinion) and higher ballpark. Literally, about a third of the wheel will stick out beyond the wheel well.
acura_dipset_tl
01-01-2016 03:02 PM
nuldabz
09-03-2015 05:49 PM
