Volk racing re30 on a TSX
hello guys,
i am searching for a defined answer but it seems like i cant get any....
anyway, i would like to seek the advise from the TSX guru here...
i am driving a TSX or some would call it the JDM CL7 Euro R spec. i have a set of volk racing RE30.
i am wondering if it could fit my ride if they are 18" 9jjj offset 50mm.. i am using a 18/225/40 by the way.
this set of rims are formely from my FD2R or the JDM civic type R..
can some guru enlightend me if it fit and what height should i drop and possible will it rubs the fender? And, wat should be a good camber angle so it will not "eat" too much of my tires?
look forward to the reply from the guru here....thks..
Not exactly your wheel size, but this other thread is worth taking a look if you haven't already. https://acurazine.com/forums/1g-tsx-tires-wheels-suspension-130/18x9-5-et30-w-235-40-18-will-they-fit-858119/ He's running 18 x 9.5 on a +30 offset, but I suspect he rolled his fenders. What kind of look are you going for?
Not exactly your wheel size, but this other thread is worth taking a look if you haven't already. https://acurazine.com/forums/showthread.php?t=858119 He's running 18 x 9.5 on a +30 offset, but I suspect he rolled his fenders. What kind of look are you going for?
i have 18x9 +35 RE30 on my tsx. However, back in 2009, i ran a 18x9+50, no finger gap drop (TEIN Basic), 245/40, and stock camber settings and it rubbed on my coilovers. I had to run a 5mm spacer for it to clear.
I'm running 18x9.5 +22 RE30. I honestly didn't roll my fenders the right way, the tires naturally rolled it for me"horrible I know". But I would recommend you rolling. With a +50 offset your going to have issues with the wheels hitting your coilovers. Like emseecoy said get spacers to lower your offset down. And im running -2.5 in the front and -4 in the rear.
GWEEDOspeedo
01-15-2016 10:39 PM
