UPS delivery woohooo!
Originally Posted by JTso
The thicker and heavier rear swaybar is known to reduce gas mileage by 2 mpg. ![Chuckle](https://acurazine.com/forums/images/smilies/chuckle.gif)
seriously? what's the weight difference?
if you were sarcastic, then
East Coast Crew
Nah, I was just messing with visuelz. ![Big Grin](https://acurazine.com/forums/images/smilies/biggrin.gif)
East Coast Crew
The hex key was the worse idea to use. I still haven't completed it since it's dark so I put everything back. I tried so hard on that hex key and I stripped that metal down to a circle. The better way is to take a wrench and hold on to the hex while using a wrench on the screw. I didnt even have time to see if everything was torqued back to place...=[. Now does anyone know where I can get a new hex thing sorta screw for the endlink?
Here was how my car looked like
![](http://www.visualx.net/tsx/ramp.jpg)
Let me chime in on the damaged hex pattern on the endlink as I have some experience here. I too stripped the key pattern and figured I needed a new end link. But what I found was that if I put the hex key in such that the long portion was parallel to the sway bar (not the overall bar, but parallel to the portion of the bar where it attaches to the endlink before it turns) and sort of pulled it to the bar, gripping both in one closed hand, it created awkward angle torque on the hex key and allowed grip on an unstripped surface, which allowed me to retighten it. If I needed to work with the thing alot I'd replace the endlink but I'm hoping I never need to remove/reinstall the thing.
East Coast Crew
East Coast Crew
dirleton
08-06-2024 08:19 PM
