The Tire Selection/Wheel Size Master Guide
#82
Bye TSX, hello domestic?
The 18x8 +40 will stick out slightly past the front fender I believe, 19x8 +42 is 2mm better, so maybe even w/ the fender. I have 18x8 +45 235/40/17 TL wheels and they are very flush.
I've said it before, rubbing is dependent on 2 things, your 1) wheel/tire sizing and 2) drop. So a 19x8 +42 will work w/ a 2" drop, a 19x8 +50 will be able to drop much more. So most wheels will "work" but you'll get a better drop w/ a higher offset. You can also use significant camber to tuck the wheels in more to achieve a lower drop w/ lower offsets, see vwong's ride.
#84
Originally Posted by hawaiiantsx
ok....this may sound dumb...but would a 2 piece 19x8 with a 42 offset have a wider lip on the wheel then a 19x8 with a 48 offset?
#85
BDI aka Booty Man
Hopefully it won't rub.
#86
not a dumb question. in general, a lower offset gives the posibility of a bigger lip all things being equal. but if you look at Volk's sizing charts, they provide different types of the same wheel, some which the same lip size even though the offset is different
#87
Has anyone tried using a 235/45/17 tire on a 17 x 7.5" wheel? I was thinking of doing this with the TSX A-spec wheels, but was wondering if the tire would be too wide. My guess is that this would be ok. The stock 215 mm wide tires are on a 7" wheel, and the 235 would be 20mm wider which is 0.79". So I guess the tires would bulge about by about 0.29", which doesn't seem too bad. Does anyone have any pics of this size tire/wheel combination?
#89
Here is the spec for S-03s: http://www.tirerack.com/tires/Spec.j...e1=yes&place=2 7.5 rims are in the range.
#94
Originally Posted by 67whitegoat
hey yeefucew, do the 245's stick beyond your fenders or are they more flush?
#95
those are larger than stock size, if you want the perfect size get 235/40/18
OEM: 17" wheel + 4.2" (tire wall #1) + 4.2"(tire wall #2) = 25.4" Total Diameter
Mine: 18" wheel + 3.8" (tire wall #1) + 3.8" (tire wall #2) = 25.6" Total Diameter
#96
Hi to everyone!
I need some help about fitment.
My car is Honda Euro Accord'04 (similar to TSX).
Finnaly I'm ready to buy new wheels for my baby...
It's Antera 349 18'-8' +45. They are great, isn't it?
My suspension is stock.
Question: Do they fits with tyres 225/45/18? 'Cos 40 profille
is too small for me. I don't want any rubbing - even when my car is full of weight.
Thank's for a help!!!
Best Wishes...
Best Wishes...
#97
Advice wanted...
235/45-17 .....4.2in .......12.7in ....25.3in ......79.6in ..............796 ..........-0.5%
It seems that if you want to go wide, this is the way to go, as it's closest to stock circumference without bumping up (or down) the rim diameter.
I want to do some weight reduction, although I live in CT, and the roads are crap, so I can't go too light, as I'd bend a rim on the first day out. I've always been a fan of OZ Racing wheels, and was considering the Supertourismo GT with a 7.5" width (I don't think they come in 8"). According to tirerack, they have a +50 offset, and weigh 20lbs each (4lbs less than stock), which is fine by me. Do you think they can accomodate 235mm wide rubber? Do you think the smaller offset, plus the wider rubber would cause rubbing if I were to get coilovers and drop it about 1" or so?
Less sidewall is always a good idea, but it seems in order to do that, I'd need to go 18", and that means extra weight. I also noticed that the RealTime folks are running 17s with 235R40, which would make for a much smaller circumference (basically a mismatch for daily driving).
So is it worth it to go 18" so I can get a smaller sidewall (therefore better steering feel)?
Oh, and yeah, I'm new here. It happens. Hi everyone!
#99
First of all, let's cover the OEM equipment specs:
Tires: 215/50-17
Wheels: 17x7, +55mm offset, 5x114.3mm (5x4.5") bolt pattern, 64.1mm centerbore
Tires: 215/50-17
i'm thinking of installing the following:
tire - 225/45/17
wheel - size: 17x8; offset: +42; backside: 5 1/2; bolt pattern: 5x4.5; weight: 14.3lbs.
#100
Originally Posted by afici0nad0
sorry, didn't go through all the pages, but, do we have a weight for each oem rim?
tire - 225/45/17
tire - 225/45/17
#102
Photography Nerd
Originally Posted by LoveMyTSX
What would be the widest tire I could mount on a 17x7 +43 offset rim?
Personally, I'd just go with the 215's.
#103
Originally Posted by Dan Martin
It depends on the tire. 215 would be the safe bet for pretty well all tires, but some may let you install a 225mm tire on a 7" rim. You'll have to look up the specs for the tire. TireRack is a good place for that information.
#106
#107
^ nice site!
the tires will fit fine, the wheels however will not. don't get wheels w/ that low of an offset
Originally Posted by gfd1182
I have an 18 x 7.5 +35 offset would 225 40 18 tires be fine?
I need some expert advise.
thanks
thanks
#108
^ nice site!
how bout those tires with +42 offset?
#112
DC Metro Local Crew
hey xizor, i am really liking the enkei RPM2, how would 18 x 8 +45 with a 235-40 tire or what is recommended to not rub, im planning on being at about 1.75 inch drop with my coilovers maybe a tad bit higher in the back. what do you think?
#113
#115
Originally Posted by hrj_1985
a little help please, im going to run 19x8.5 ET 56 w/ 235/35/19 tire, i already lowered my car at least 2", will they rub?
#118
DC Metro Local Crew
should be ok, i had 17x8 +45 235/45/17 and rubbed a little with a 2.5"+ drop, so 1.75 will be ok
#119
Living the Dream
Would this tire be best on a 17x7.5 or 17x8? Probably a 45 offset. Would this stick out of the wheel well?
#120
DC Metro Local Crew
hey guys, got a quick question, just picked up some enkei rpm2's and have been reading up on centerbores. Now i know that the enkei's are 73mm centerbore and the tsx 64.1mm. Now do i still need to get centering rings or if i tighten the lugs the correct way with the rim off the ground, would i be in the clear with vibration? Heres a link i snagged off google. Do you have to get a specific manufacturers wheel center spacers? Or can i get something like this? or do i need them at all? I really want to make sure i get this done correctly and not have problems once my rims come in. Help is greattly appreciated.
http://www.ppsonline.net/wheel_centre_ring.htm
