Tire Pressure
Tire Pressure
So far, I never filled air in my 1.5 months old TSX but yesterday i noticed front tires looking somewhat deflated so I decided to fill air but to my surprise, tire pressure was already 32/30 psi in front and back as recommended.
Is it normal? I am pretty sure the front tires were not looking this deflated before.
Originally Posted by hrj_1985
its probably flatspotting, it happens when you left your car on a spot for a long period of time.
Someone stole "My Garage"
Originally Posted by visuelz
So that means the wheel won't turn as a circle, therefore more gas is wasted? =[
To the original poster -- I prefer to run my tires higher than the recommended. I use around 36F/35R and it feels great. Many others use a higher-than-recommended pressure as well. Run a search for the "-10% rule" as that's what I've based my pressures off of (with a bit of downward adjustment to get a more comfortable ride).
I believe the recommended pressures are 32F/30R but I've been driving with 36F/34R. I even had it up to 38F/36R for my last road trip to Nor Cal to get better mileage.
Really???
Why not drive at high pressures everyday then?
Originally Posted by tsx_07
Really???
I see..but out of curiousity, did it actually give your better mileage? I have been getting about 22-23 mpg (75% city, 25 % highway) but i have just 2500 miles on it as of now. i understand after 4-5k, it probably should shoot upto 27-28 in similar driving conditions.
Your mileage should improve as you get closer to 8K-10K miles. Mine did. And, yes I did get better mileage with higher tire pressure. Coming back from Nor Cal I averaged just under 35mpg for the tank, got something like 514 miles before refilling.
Originally Posted by dom
So I take it you don't have an 07 TSX?
Originally Posted by alucardx
benefits: being a lazy piece of a crap and not checking the tire pressure the old fashioned way
I'm all for not being a lazy peice of crap and doing it the old fashioned way but the TPMS system in the 07 TSX doesn't fall into that category. I bet 2% of people check their tire pressure regulary. This ensures safety and better MPG as people will now start paying alot more attenton to their tires. Its about time.
C'mon, man! Row yer own.
I run 36/34 usually. Works great, good balance between comfort, handling, and mileage. Sometimes 34/32 in winter when everything seems to be stiffer, gives a little more comfy ride. Be mindful of the 10-deg rule (+/- 10F = +/- 1psi) -- the colder it is out, the lower the pressure will be in your tires aotbe.
mugen_kid
11-13-2015 10:38 PM
NBP_BALLER
09-23-2015 08:18 PM
CostcoFanAUS
09-18-2015 06:05 AM
HeloDown
09-08-2015 06:51 PM
