Tire mounting options? Walmart?
Old 09-05-2008 | 11:23 AM
yadnom's Avatar
I was wondering if anyone has had experience with Walmart's tire service?
Specifically, I'm thinking about ordering tires online (tirerack or discounttire)and then having Walmart mount and balance. It looks like it might be cheaper to have it done there.
Also why is there such a huge price discrepancy on same tires between discounttire and discounttiredirect? Are the tires on direct older or something?
Thanks for any info.
Old 09-05-2008 | 12:14 PM
CGPTSX06's Avatar
It might be cheaper there if you M&B your stockers but if you have aftermarket wheels I highly recommend you to go to a shop that has the right equipment to do aftermarket wheels that is touchless tire mounting and such they use high end equipment such as Hunters, you may pay a little bit more but you will be satisfied at the end.
Old 09-05-2008 | 12:16 PM
yadnom's Avatar
Yea, this will just be replacing the stockers. I've got about 53k on them and one of them has a bubble probably from pothole so they need to be replaced soon.
Old 09-23-2008 | 12:08 AM
patriot1991's Avatar
Wal Mart is fine, i used to work in the auto shop there back in the day. Just be sure you get an experienced person to do it and that you go over scratches on the wheels before and after the install so they are accountable. They also provided a lifetime balance, rotation and road hazard pretty cheap for the lifetime of the tires
1fatcrxnem1
22
06-01-2018 01:23 AM
KB1_EJ6
11-13-2016 09:51 PM
KB1_EJ6
08-28-2016 08:25 AM
datadr
09-02-2015 06:46 PM
Quick Reply: Tire mounting options? Walmart?
