Time for brake job... Upgrade recommendations please
#41
Originally Posted by Asahi
Just to chime in on things I do know about . . .
Hawk HP+ are much better pads for initial bite than the HPS. Hawk in general is a good pad but watch for the shims to come loose. Had this happen ona few sets.
As far as the shims go, if they're coming loose just use more grease between the shim and pad.
#42
Use all 3 Pedals at once
Originally Posted by Nighthawk04
Here are my new PowerSlots and Hawk HPS's. Thus far I've only bed-in the pads so I've still got another 380 miles to fully break-in the rotors. Even though the system isn't fully broken-in yet, the initial bite of the Hawk HPS's against the PowerSlots is much much better than stock.
The only thing that I found interesting about the install was that there are two (2) shims on each inner brake pad. I've never seen that before but hey, I've never had such a nice car.
And I'd also like to give special thanks to Performance Parts Store (PPS) for giving me such a sweet deal on these rotors and pads ($240 shipped for both rotors and the pads)! Their info is available here: http://www.club3g.com/forum/showthread.php?t=25719 . The prices they have listed there are for the 3g Eclipse but if you call them and tell them that you saw the group buy on club3g.com, they'll give you the same pricing that they gave me.
It that price ($240 shipped) only for the front set? If so, how much for the rears also?
#43
The HP+ is a nice pad but its full abilities can rarely ever get used on the street. Also, the HP+ takes longer to warm up than the HPS, which means that the HPS's initial cold bite for those of us who live up north will be much better than the HP Plus' initial cold bite. Lastly, given the more abrasive compound of the HP Plus, it will chew through rotors more quickly.
I've used both HP+ and HPS and neither has any significant need to be warmed up. Neither is a track specific pad and the biggest heat difference between an HPS and HP+ is that the plus will fade less at high temps.
The HP+ compound has never rapidly chewed up a rotor of mine and privide much better initial bite even in the winter. I'v run them year round and same with the HPS and the HPS just wasn't worth the money.
All of that said the Cobalt GT Sport has slightly better bite than the HP+, way better modulation and is easier on rotors. They also lasts longer.
#44
I will say that the rotor break-in and the pad bed-in processes for both sets of rotor rings and both sets of Hawk pads was exactly the same. Almost the same external temperature, exact same test area, no part of break-in/bed-in process was significantly different.
In terms of the driving that I did, some stop-and-go, some highway, some autoX, I noticed a very little difference between pad performance at high temps..
#45
#46
Originally Posted by moda_way
I'm staying stock wheels as well, so I just ordered Brembo front rotors, some ceramic matrix pads and a set of SS lines all around. I haven't found any aftermarket rear discs except from Stillen.com (the fronts and rears are cross-drilled), but I'm only replacing the fronts as they are terribly warped and I don't want to go get them resurfaced; it'll just happen again.
You can also get a set of PowerSlots for the front from TireRack.com. They had the best price I've seen on the Brembo's too.
Got my Brembo sitting at the house and they are REALLY nice for a stock setup.
If you are wanting to do the cross-drilled OEM size, PM me. My buddy is a distributor and can possibly help you out. He took care of my pad and SS lines order.
Moda, did you go with Cross drilled Brembo's? Tirerack has a Bembo replacement rotor for $57 each, I'm guessing thats what you purchased?
Also wondering if anyone knows who makes the OEM rotors. Mine are warped to high hell as well and I want to be absolutely sure I don't buy the same rotors.
#47
#48
Damn, I ran HP+ pads with the Baer kit on my Eclipse and they killed the brand new 13"x1.1" rotor rings after 9,000 miles. Cold bite in the freezing Chicago winters was horrible until after I got 10 - 15 hard stops in. The HPS on the other hand has been used with a new set of the same rings for the past 15,000 miles and the rotors still have loads of thickness. Cold bite with the HPS is great initially and requires no hard stops.
There's obviously a temp diff btwn. SE TN and Chicagoland. Andie Lin of Cobalt mentioned to me that he rates Ferodo DS2500 as probably the best cold temp high-performance pad with axxis ultimates and gt-sports less about equal for cold temperature stopping. I've found that gt-sports can take temps into the teens w/ little incident, but I adjust my driving accordingly. I do believe HPS will take about OEM operating temp ranges, whereas high-performance pads are pretty much not very good below freezing. Temp. can affect adherent vs. abrasive friction and cause differences in wear.
#49
I still like the Cobalt GT Sport the best. I called Andie at Cobalt tonight and he said he thought the GT SPorts for the TSX were readily available. He's supposed to send me an email now that he is back in town and let me know pricing and such.
#50
Dom, before you bother replacing the rotors try scuffing the rotor on both sides with a coarse sand paper. Warpage is often misdiagnosed when it is actually uneven pad material transfer onto the rotor allowing different grabbing forces.
The scuffing should remove the material and allow the pad to re-bed.
#51
ALways good advice from Bill and I've only been here for a week
#52
Yeah, I went with the plain vented Brembos up front. I just found the part number for the rear solids from Brembo. Took them a while.
As far as OEM, I'm sure Honda Japan has a contract with some... and I'm 99.99% sure it ISN'T brembo based on the cooling profile of my new brembo fronts.
#53
After doing dome reading around here yesterday I'll probly have the rotors machined and have new pads put on before going to new rotors. The rotors I have on only have 20K on them so I'd hope there still useable.
#54
I use Garnet paper, as I've heard that aluminum oxide can actually stick to the rotor in sufficient quantity to become loci for judder and noise issues, even after being cleaned off with solvents like acetone, isopropanol, etc. Al oxide is okay for sanding pads, AFAIK, as many already contain it in their formulations.
#55
Sometimes machining works, but I either just sand or junk my rotors.
mada51589
05-03-2022 08:54 PM
IIDXholic
10-08-2015 07:53 AM
nuldabz
09-03-2015 05:49 PM
