Time for brake job... Upgrade recommendations please
1 Post
I believe I need my rotor resurfaced and pads replaced. So, what upgrades can I consider where cost won't stray to far from cost of regular brake job? FYI, I have stock rims.
Thanks!
Thanks!
I'm staying stock wheels as well, so I just ordered Brembo front rotors, some ceramic matrix pads and a set of SS lines all around. I haven't found any aftermarket rear discs except from Stillen.com (the fronts and rears are cross-drilled), but I'm only replacing the fronts as they are terribly warped and I don't want to go get them resurfaced; it'll just happen again.
You can also get a set of PowerSlots for the front from TireRack.com. They had the best price I've seen on the Brembo's too.
Got my Brembo sitting at the house and they are REALLY nice for a stock setup.
If you are wanting to do the cross-drilled OEM size, PM me. My buddy is a distributor and can possibly help you out. He took care of my pad and SS lines order.
1 Post
Looks like I've been away for a long time... After seeing Moda_way's avatar, I believe congratulations are in order! Congratulations Ryan!
And thanks for the advice. I will look into the upgrade and see how much it would cost. I have to make the decision soon. I'd like to give myself a chance at attempting to upgrade the rotors. Never done it before. I'd also have to make sure I have the proper tools. Do we have a DIY on this? I'll have to do a search.
Thanks. That's Ethan and he turns 1 yrs old in July.
I looked into the upgrades as well and obviously any big brake kit will require larger wheels. Because I have a second set of OEM wheels, I'm staying stock size.
Hardly any tools are needed because the rotors come right off with 4 bolts and there are ony 2 bolts to remove the caliper. The bolts (I think they are phillips heads) are torqued on, so you need some good leverage for it.
1 Post
I'm also trying to find out if I can reuse the shim kit. I pretty certain you can.
Are there any big brake kits that can be used with stock wheels? I have aftermarkets for spring, summer and fall but, I'll need to put the stock wheels back on for the winter.
I was also looking to do Motul fluid, but I think we have to stay Dot 3 or 4 and Motul is Dot 5.1 and higher. Plus, I didn't want to make a mistake in the future and really mess the system up.
I know, of the kits I looked at (Brembo, Rotora, Spoon, etc), all required larger wheels because the upgraded calipers needed more space. The only option I know of is upgrading the rotors of which there are a few. Combine that with SS lines and better brake material, a larger brake kit isn't as necessary. My buddy at Stillen.com turned me on to their brake material and SS lines. I would've done slotted rotors, but I need the funds for other things. I'm not personally interested in cross-drilled in an OEM size.
I have about 6K miles on my car now no problems so far, just wanted to know my options.
1 Post
Well, after doing some searches, I saw that "shuddering" which is what I'm experiencing now, is most likely caused by warped rotors. The reason I thought of resurfacing the rotors was from past experience when shuddering was occuring. What I didn't think of is that it may be under warranty? Deferring the cost of an upgrade or brake service is looking good to me right now after the wife just (lightly) rear ended someone with her MDX. With the $500 deductible, no cost to fix shuddering is a
So, can someone confirm if this is indeed can be covered under our warranty? I only have 29700 miles.
Thanks!
Thanks!
Well, after doing some searches, I saw that "shuddering" which is what I'm experiencing now, is most likely caused by warped rotors. The reason I thought of resurfacing the rotors was from past experience when shuddering was occuring. What I didn't think of is that it may be under warranty? Deferring the cost....
Originally Posted by JTso
When you get a chance after removing the stock rotors, could you put them on a scale and see how much they weight? I was helping someone to install a set of Brembo blanks and they were much heavier than the stock rotors.
If my pads and SS lines arrive on Friday as planned, should be doing them on Sat. or Sun.
Bye TSX, hello domestic?
There is also one large nut to remove. It is notched, so you have to first bend the notch back up (not hard metal) and then remove.
Originally Posted by xizor
Those 2 screws were a PITB (or is it PIITB ) to get out. I had to buy an impact screwdriver (the kind you hammer) to get them out because they were stripping when I used a regular phillips head.
You don't need to remove the nut to take off the rotor. Its for removing the hub from the axel.
Thanks for the clarifications on the nut. I the shop manual I thought it had mentioned taking it off. Glad to know this because I wasn't too happy about that part.
My front rotors are warped at 21,000 miles. I recently ordered my PowerSlot rotors and Hawk HPS pads from Performance Parts Store (PPS). I paid $242, which is $55 cheaper than what I would've paid through TireRack. Here's the thread: http://www.club3g.com/forum/showthread.php?t=25719 ; my screen name on that board is "Phil". It's a great vendor, feel free to check out the Good Guys/Bad Guys forum on that board.
Originally Posted by mg7726
phil - lemme know they work. once my pads go, i'm replacing the whole rotor/pads set.
I'm sure that the PowerSlots and HPS's will be awesome on my TSX.
I replaced my front rotors with the blank brembo replacements and the pads with hawks hps. Great diferrence in stopping, only a little dust in the front wheels.
If you change your stock tires to Yoko AVS ES100 or Avon Tech M500 you will increment stopping also.
Drives With Hands
I was looking into some Stoptech Aero-rotors, which are direct replacement for our OEM rotors. Only they are slotted, and I think they're mounted with a hat though I'm not sure.
Stoptech doesn't make Aero-rotors for the TSX yet, that I've been able to find. However they make them for the RSX-S. Doesn't the TSX use brakes from the RSX-S? I thought maybe the Aero-rotors for the RSX-S would fit, but I'm not going to chance it until one of you schools me (hopefully).
1 Post
The dealership covered my front brakes but did not cover the rear. Something about my front pad still at 60% but the rear was at 10% so they could only cover the front.
Oh well. Brakes feels much stable after paying $215. I had a coupon
Here are my new PowerSlots and Hawk HPS's. Thus far I've only bed-in the pads so I've still got another 380 miles to fully break-in the rotors. Even though the system isn't fully broken-in yet, the initial bite of the Hawk HPS's against the PowerSlots is much much better than stock.
The only thing that I found interesting about the install was that there are two (2) shims on each inner brake pad. I've never seen that before but hey, I've never had such a nice car.
Before bedding-in the pads:
After bedding-in the pads:
And I'd also like to give special thanks to Performance Parts Store (PPS) for giving me such a sweet deal on these rotors and pads ($240 shipped for both rotors and the pads)! Their info is available here: http://www.club3g.com/forum/showthread.php?t=25719 . The prices they have listed there are for the 3g Eclipse but if you call them and tell them that you saw the group buy on club3g.com, they'll give you the same pricing that they gave me.
Originally Posted by kaikai114
Moda and Jtso, does having lighter weight rotors give faster acceleration (less unsprung weight)?
Originally Posted by Nighthawk04
Yes, less unsprung weight and even more importantly less rotational mass will make a positive impact on accelerating, braking, and turning performance.
And a negative impact on brake fade, unless you use a two-piece rotor with lightweight hat.
Drives With Hands
Just to chime in on things I do know about . . .
Hawk HP+ are much better pads for initial bite than the HPS. Hawk in general is a good pad but watch for the shims to come loose. Had this happen ona few sets.
Another brand I use a lot on my Type-R and are some of the best brakes I have used for performance is the Cobalt Friction Technologies GT Sport brake pads. www.cobaltfriction.com (Hopefully posting links here is allowed).
There are plenty of other good pad companies too like:
Porterfield
Carbotech
Hawk
Cobalt
I personally like the ones above and have had no good experience with EBC or Axxis. As a side note slotted and drilled rotors are a waste in general and changing to a high performance fluid can be a useful upgrade if any tracking of the car is happening.
Porterfield
Carbotech
Hawk
Cobalt
The fact that they're $135 for front TSX GT-Sport pads wouldn't dissuade me a bit, but the special order status seems annoying - I'd probably buy two sets, just in case.
I've only had my TSX for 4 days so I had not checked into availability. If I get any info I'll pass it on.
__________________________________________________ ____________
FWIW, probably the FIRST brake upgrade would be ditching the shitty OEM Michelins for a summer-only UHP tire, or at least an A/S UHP tire, if the climate dictates such; the Michelin Pilot HX isn't even classified as a performance tire and the majority of Tirerack surveyed owners would "definitely not" buy it again
