Tein vs. RS*R opinions needed
Old 11-09-2008 | 01:32 PM
GTSX-05's Avatar
ASM 3G TL Type-S
Hey guys,
I am looking for some help; I currently have two sets of springs and shocks for my TSX. Tokico shocks (currently riding on) which I am replacing with Koni Yellows. I also have RS*R down springs which I am currently riding on with the Tokico’s.
Should I keep the RS*R’s or swap them with Tein S-tech’s that I have lying around in my garage. I was wondering.
Here are the spring rates and information for both manufactures.
RS*R springs
Lowering 40mm front / 30mm rear
Spring Rate 6.25kg/mm front / 3.25 kg/mm rear
40mm = 1.5" front
30mm = 1.1" rear
Tein S-Techs
Spring Rate (lbs/inch) 6.2/347 2.7/151
Ride Height Drop (inch) -1.7 -1.3
Since I am running the Mugen under-spoiler kit I am already pretty happy with my wheel to fender / ground clearance, however I was wondering if anyone would know how to dissect the spring rates and figure out what would be better to run with the Koni’s.
help>?
Old 11-09-2008 | 09:48 PM
chuson's Avatar
T.DoT P.I.M.P. lol
help>?
Gary, I thought you plan to sell the Mugen front lip??
The differences between the two is small, I think once you swap the shock you are good, it's up to you to swap the shocks or not.
The spring rate on both spring are relatively soft, consider my BuddyClub is 14K/8K.
Old 11-10-2008 | 12:40 PM
MrHeeltoe's Avatar
Former Sponsor
You might get sharper flatter handling with the RSR and maybe a little softer ride with the Teins. They are so close....its probably not worth spending the money to change if you like the RSR now.
http://www.heeltoeauto.com/home.php?cat=3391
Marcus
notfast
1/2G MDX (2001-2013)
03-28-2023 09:10 AM
TLrascal
08-04-2018 12:00 AM
Joseph Stansbury
34
12-04-2015 02:57 PM
handsom-hustla
11-13-2015 06:04 PM
nanos
11-12-2015 09:41 PM
Quick Reply: Tein vs. RS*R opinions needed
