Tein SS Users, What damper settings?
oo revival!
anyways, what settings will cause tire rub? I put mine back at 8's after discovering they were on stiffest 0 (tried to twist clockwise (stiffer) but was really hard, so i twisted 3x ccw, then 3x cw and confirmed it was hard to twist, then 8x ccw again)
I wanted a smoother ride so going more cw will be better for this purpose?
Registered Abuser
i put my fronts on 10 also, and finally got the energy to adjust the rears to 8. i drilled a tiny hole on the upper platic part of the seats so i don't have to completely remove anything.you have to really push the leather to the side to see the hole. just stick the key in and turn.
Let me help you!
I even forgot there was a key. Now I wonder where I placed it...
Edit: To answer OP's very old question, I am currently running on 12 both in front and back. I use 1 front and back when I'm on long road trips (or carrying passengers). I used to make the front more stiff than the rear by two settings so that my rear sway bar would have something to do, but now I figure I'll just make everything even and the sway bar can pick up the slack.
Silvermoon_Knight
10-22-2015 06:25 PM
braveheart
09-07-2015 08:12 AM
